    XML Tools 3.0.3.3 delay N++ start for TWO minutes
    3 Posts 2 Posters 256 Views
    • JoseLuis C.B.J
      JoseLuis C.B.
      Hi.
      After upgrading N++ to last version (7.8.5 32 bit), also updated plugins.
      After this, N++ starts, but remains unavailable for almost two minutes.
      I checked with previous N++ 7.8.4 with same effect.
      If disable XML tools plugin, it start normally.
      Is it any way to get an older XML Tools plugin?
      How to report such error?
      Thanks everybody!
        Ekopalypse @JoseLuis C.B.
        @JoseLuis-C-B said in XML Tools 3.0.3.3 delay N++ start for TWO minutes:
        You can report it here, but it looks like there is already a fix.
        See here, with version 3.0.3.4 there has been a fix implemented
        which addresses a performance issue.
        JoseLuis C.B.J 1 Reply Last reply Reply Quote 2
        • JoseLuis C.B.J
          JoseLuis C.B. @Ekopalypse
          Thanks a lot @Ekopalypse. It works perfect (as expected!!)
