    Need help on replacing text
    13 Posts 2 Posters 3.6k Views
    • Claude CadieuxC
      Claude Cadieux
      @Alan-Kilborn said in Need help on replacing text:
      ABT(?= \d{4}-\d{4})
      Worked perfectly. Thank you very much.
      This topic may be closed.
      Claude
      • Claude CadieuxC
        Claude Cadieux @Alan Kilborn
        ABT(?= \d{4}-\d{4})
        Sorry to ask another question about this.
        The change worked from ABT to BET but I must make another change if you can spare a moment.
        I need to change this line:
        2 DATE BET 1676-1678
        to this:
        2 DATE BET 1676 AND 1678
        Replacing the “-” between the 2 dates by " AND "
        Thanks again.
        Claude
          Alan Kilborn @Claude Cadieux
          @Claude-Cadieux
          So given our first exchange, might you see which part of that pattern I provided matches four-digit years? Go ahead, take a guess! We’ll be kind.
          While we do like providing help, we really enjoy it when people take the help provided and apply it to new problems. Makes us happy.
          Claude CadieuxC 1 Reply Last reply Reply Quote 2
          • Claude CadieuxC
            I did look at your example and tried some variant but they did not work. Then went to look at Regex example online but man, at 65 I must say that I am a bit overwhelmed.
            I tried this:
            -(?= \d{4}-\d{4})
            I tried this:
            -(?= \d{4}-\d{4})
            Can’t get a match and also, I need to insert a blank before and after “AND”.
            \bAND\b ??
            Thanks
            Claude CadieuxC 1 Reply Last reply Reply Quote 0
            • Claude CadieuxC
              Claude Cadieux @Claude Cadieux
              @Claude-Cadieux said in Need help on replacing text:
              -(?= \d{4}-\d{4})
              Sorry on the second try I did this:
              -(?= \d{4}-\d{4})
              Claude CadieuxC Alan KilbornA 2 Replies Last reply Reply Quote 0
              • Claude CadieuxC
                @Claude-Cadieux
                Backslash does not show here \-(?= \d{4}-\d{4})
                  @Claude-Cadieux
                  So to match a 4-digit year you can use \d{4}. That means “a digit character repeated 4 times”.
                  A blank is not \b. A blank space is just a blank space in your expression.
                  \b is actually a word-boundary.
                  It is best to show expressions surrounded by backticks; they will appear like mine do, in red.
                    Alan Kilborn @Alan Kilborn
                    @Claude-Cadieux
                    I would not believe you if you said anything different. :-)
                    So by now you should be matching 1968-1974 as \d{4}-\d{4} ??
                    Admittedly, my earlier stuff with (?= before it might have been misleading. Forget about that now (advanced usage).
                    • Claude CadieuxC
                      Yes this did work: \d{4}-\d{4}
                      But it must be on a BET line:
                      2 DATE BET 1625-1629
                      So this also works to find the right line
                      BET(?= \d{4}-\d{4})
                      But I do not know how to specify the “-” being the target to change by " AND "
                        @Claude-Cadieux
                        So there may be something to learn here. With BET(?= \d{4}-\d{4}) (you didn’t apply my “backtick” advice when you stated it), you can’t possibly influence the - because the (?=...) part of that doesn’t match any text, it just means that the specified text must be there. If you don’t match the text you want, you can’t replace it. (Remember, originally, all we wanted to replace was some fixed text before the (variable) year range).
                        You might have good luck searching for BET (\d{4})-(\d{4}) and replacing with BET \1 AND \2.
                        You put grouping parentheses around variable text that you want to substitute in at replace time, as I’ve done here. Then, to refer to the first capturing group, at replace time you reference it with \1. Similar for the second grouping.
                        But really, this isn’t a forum about regular expressions, so time to buck up and learn a bit more than just your immediate need covers. There’s some good pointers here: https://community.notepad-plus-plus.org/topic/15765/faq-desk-where-to-find-regex-documentation
                        • Claude CadieuxC
                          BET \1 AND \2
                          Thank you so much for your time and patience and the link.
                          There’s always something new to learn.
                          Claude :-)
