    Shortcut or menu path to "Rotate to right/left"
    18 Posts 5 Posters 3.6k Views
      What I think the problem was is that a newly created script hasn’t been assigned
      an ID known to npp. This is normally done during plugin initialization where npp
      asks for functions to register, hence the restart of npp solved it.
      • deleeleeD
        deleelee @Ekopalypse
        @Ekopalypse said in Shortcut or menu path to "Rotate to right/left":
        A python script might look like this
        import ctypes
        ROTATION_A_LEFT = 2000
        ROTATION_A_RIGHT = 2001
        WM_COMMAND = 0x111
        def isSingleView():
            npp_hwnd = ctypes.windll.user32.FindWindowW(u'Notepad++', None)
            splitter_hwnd = ctypes.windll.user32.FindWindowExW(npp_hwnd, None, u'splitterContainer', None)
            return (not bool(ctypes.windll.user32.IsWindowVisible(splitter_hwnd)), splitter_hwnd)
        def LOWORD(value): return value & 0xFFFF
        single_view, hwnd = isSingleView()
        if not single_view:
            ctypes.windll.user32.SendMessageW(hwnd, WM_COMMAND, LOWORD(ROTATION_A_LEFT), 0)
        A few years old but it still works!!! I’ve been wanting a toolbar button for rotating the panes and this is great. Do you know if it would be possible to have the script toggle so that it rotates one way on the first click and back the other way on the next click? As it is, the first click rotates in the desired direction but the next click rotates once more in the same direction which doesn’t return the panes to the order they were in, so it requires three clicks to do that. Obviously, I could just have two buttons, one for right and one for left, but it would save toolbar space if they were combined into one button.
          Ekopalypse @deleelee
          @deleelee
          Oh dear … When I see this old code, what was I thinking? :-D
          let’s create a new property of the notepad class and store the state there.
          import ctypes
          WM_COMMAND = 0x111
          def isSingleView():
          if not hasattr(notepad, "rotateSplitView"):
              notepad.rotateSplitView = False
          if not single_view:
              if notepad.rotateSplitView:
              else:
                  ctypes.windll.user32.SendMessageW(hwnd, WM_COMMAND, LOWORD(ROTATION_A_RIGHT), 0)
              notepad.rotateSplitView = not notepad.rotateSplitView
          But nowadays I guess I would do something like
          from ctypes import wintypes, WinDLL
          from Npp import notepad
          class ViewRotator():
              def __init__(self):
                  self.LOWORD_LEFT = 2000
                  self.LOWORD_RIGHT = 2001
                  self.WM_COMMAND = 0x111
                  self.toggle_rotating_direction = False
                  self.npp_hwnd = WinDLL("user32").FindWindowW(u'Notepad++', None)
                  self.splitter_hwnd = WinDLL("user32").FindWindowExW(self.npp_hwnd, None, u'splitterContainer', None)
                  self.send = WinDLL("user32").SendMessageW
                  self.send.argtypes = [wintypes.HWND, wintypes.UINT, wintypes.WPARAM, wintypes.LPARAM]
                  self.send.resttype = wintypes.LPARAM  # LRESULT
              def isSingleView(self):
                  return not bool(WinDLL("user32").IsWindowVisible(self.splitter_hwnd))
              def rotate(self):
                  if not self.isSingleView():
                      if self.toggle_rotating_direction:
                          self.send(self.splitter_hwnd, self.WM_COMMAND, self.LOWORD_RIGHT, 0)
                      else:
                          self.send(self.splitter_hwnd, self.WM_COMMAND, self.LOWORD_LEFT, 0)
                      self.toggle_rotating_direction = not self.toggle_rotating_direction
              notepad.rotateSplitView = ViewRotator().rotate
          notepad.rotateSplitView()
            Alan Kilborn @Ekopalypse
            @Ekopalypse
            I think you mean restype
            Any reason not to use notepad.isSingleView() instead of writing a custom function?
            Yep, we all feel this way about our own old code. :-)
            It’s because we’ve learned so much since the time of original writing.
              Ekopalypse @Alan Kilborn
              @Alan-Kilborn said in Shortcut or menu path to "Rotate to right/left":
              Yes, I do, thanks for pointing that out.
              No, I just hadn’t thought about whether there were any builtin methods.
              … and still learning … :-D that’s the beauty of this work, at least for me.
                Ekopalypse @Ekopalypse
                @deleelee
                UPDATED VERSION
                    def __init__(self):
                        self.send.restype = wintypes.LPARAM  # LRESULT
                    def rotate(self):
                        if not notepad.isSingleView():
                            else:
                Alan KilbornA deleeleeD 2 Replies Last reply Reply Quote 4
                  @Ekopalypse
                  This is an interesting approach to remembering toggle_rotating_direction from run to run of the script. Side note: IMO the name of that variable could have been better.
                  If I were writing that script, I might have remembered only the variable in the notepad variable (i.e., notepad.toggle_rotating_direction = …) instead of the function.
                  Your way has the advantage that you’ve added a general purpose function (notepad.rotateSplitView()) that could also easily be called by other scripts.
                    Sure, but I’m constantly struggling to name things.
                    What would be your choice? change_rotating_direction?
                    I had the same thoughts and decided to use a function because it can easily be modified to use a parameter to get either a split landscape or portrait view.
                      The reason toggle_rotating_direction isn’t good IMO is because, every time the code runs a toggle happens, and not just when toggle_rotating_direction is true.
                      what would be your choice?
                      Hmm, for this one, since it is a boolean, I might go with next_rotate_is_to_the_right.
                      With something like that, true/false makes sense.
                      Of course, this is all up to individual taste.
                      Yes, it is hard sometimes. Often what I do is to name something zz or zzz and just barrel ahead coding with that. Later, like when I’ve completed the local block of code, a good name surfaces and a rename fixes things.
                      I find that if I spend the time up front to come up with a great name, the code to be written changes the meaning somewhat and the great name is no longer great. So I end up taking the time to come up with 2 good names instead of just 1. Naming after the fact seems a viable technique, at least for me.
                      Of course I don’t do this 100% of the time, just when a suitable name doesn’t immediately come to mind.
                      • deleeleeD
                        @deleelee
                        UPDATED VERSION
                            def __init__(self):
                            def rotate(self):
                                    else:
                        Wowsers!!! That is perfect. Thank you so much.
