    Regex for Searching <HEAD> Section
    3 Posts 3 Posters 582 Views
    • aksarbenA
      aksarben
      I want to use Notepad++ to find soft hyphen characters (ISO 8859: 0xAD, Unicode U+00AD SOFT HYPHEN, HTML: ­ ­) in the <head> section of my HTML files. I tried the two regular expressions below, but both return zero hits.
      <head>.*?­.*?</head>
      <head>.*­.*</head>
      Curiously, the following regex does finds soft hyphens in <figcaption> sections:
      <figcaption>.*?­.*?</figcaption>
      I suspect the issue is that the <head> section contains newlines. I tried the search with the “. matches newline” both checked and unchecked. Still got zero hits both ways.
      Is there a way to do this kind of search in Notepad++?
        Alan Kilborn @aksarben
        @aksarben
        I think the code blocks you used above are hiding your soft-hyphen character, at least visually. I find that if I copy and paste them into Notepad++, the soft-hyphen character reappears.
        Anyway, I would try searching for: (?s)<head>.*?\x{00AD}.*?</head>
        I think there have been some recent postings about Unicode characters used explicitly in the Find-what box of the Find dialog not working correctly…?
          Hello, @aksarben, @alan-kilborn and All,
          Simply, use this regex S/R :
          SEARCH (?s)(.*?<head>|\G)((?!</head>).)*?\K\xAD
          REPLACE Any SINGLE character or STRING
          Notes :
          • I assume, of course, that there only one section <head>........</head> per file
          • The <head>........</head> section can be, either, in one line or splitted into several ones
          • Any soft hyphen, found, above the starting tag <head> is ignored
          • Any soft hyphen, between the starting and the ending tag is found, individually
          • Any soft hyphen, found, under the ending tag </head> is ignored
          • Preferably, when testing on a single file, tick the wrap around option, which forces to starts the S/R process from the very beginning of the file
