    Scintilla script help for 'Show white space and TAB'
    7 Posts 3 Posters 708 Views
    • LAPIIIL
      LAPIII
      I made a Feature Request on Sourceforge and they said I could solve my issue with SCI_SETWHITESPACESIZE(0) which produces 0 sized dots? Which file do I tweak?
        @LAPIII said in Scintilla script help for 'Show white space and TAB':
        That’s not in the default config files. But @dinkumoil’s ExtSettings might be able to handle it (or he might add the feature).
        If not, then a scripting plugin (like NppExec, Python script, LuaScript) would be able to send that message to scintilla, and should be able to be configured to do so every time you load Notepad++
        • rinku singhR
          rinku singh
          your question is wrong as @PeterJones said scripting plugin (like NppExec, Python script, LuaScript) i had suggest you you should ask here for Show white space and TAB python script help
          now create a new post
          • rinku singhR
            rinku singh
            link text
            • rinku singhR
              rinku singh
              ExtSettings plugin
                PeterJones @rinku singh
                @gurikbal-singh:
                Thanks for showing how to do it in ExtSettings.
                However, you said,
                The question was not wrong. It was a good question. The answer may have been “not in the native interface” – but since there are two ways to implement it ( scripting, or the plugin), it’s something that is quite readily doable in Notepad++
                Why create a new post, rather than continuing in this thread? I would actually say here is better than starting a new post.
                If I hadn’t thought ExtSettings would handle it, and had had a few minutes to experiment/verify, I would have given the Python script solution right away. But since the plugin answer is simpler and more convenient, I’ll leave it at that.
                  @PeterJones said in Scintilla script help for 'Show white space and TAB':
                  When have you known me to leave it at that? ;-)
                  To set the whitespace size with a scripting language (in case you don’t want to use ExtSettings):
                  • PythonScript: add the following to your startup.py (or to another script you call from startup.py:
                      editor1.setWhitespaceSize(0)
                      editor2.setWhitespaceSize(0)
                  • NppExec:
                  1. Plugins > NppExec > Execute, type in:
                     set local x = $(FILE_NAME)
                     npp_switch $(LEFT_VIEW_FILE)
                     sci_sendmsg SCI_SETWHITESPACESIZE 0
                     npp_switch $(RIGHT_VIEW_FILE)
                     npp_switch $(x)
                  2. Save…, pick a name (like ZeroWhitespaceSize)
                  3. Plugins > NppExec > Advanced Options
                  4. Execute this script when Notepad++ starts = ZeroWhitespaceSize
