    Hang on MenuIcons + Hide menu bar + Right click
    2 Posts 2 Posters 462 Views
    • nanocaiordoN
      nanocaiordo
      Hello folks,
      On Windows 10, enabling MenuIcons 1.2.2 plugin, selecting “Hide menu bar” from Notepad++ preferences and then right clicking anywhere inside any tab, with or without selecting text, will cause Notepad++ to hang for about one minute. It doesn’t crash, just hang and no menu will show up.
      I’ve removed the plugin even because I wasn’t really using it anymore and it’s all good now.
      Is it just me or is it reproducible.
      • rinku singhR
        rinku singh
        this can be fix via another plugin uninstall
        if there another plugin has culprit. ex.
        Notepad++ v7.8 (32-bit)
        Build time : Oct 5 2019 - 22:30:37
        OS Name : Windows 7 Ultimate (32-bit)
        OS Build : 7601.24289
        Plugins : 3P.dll BetterMultiSelection.dll Console_output.dll CustomFileMerge.dll MenuIcons.dll mimeTools.dll NppConverter.dll NppExport.dll NPPJSONViewer.dll nppRegEx.dll NppTextFX.dll Remove_dup_lines.dll
