    Using OR in replace. How to adress given group?
    6 Posts 4 Posters 543 Views
    • Adam ProchowskiA
      Adam Prochowski
      Hello,
      When using find, you can do something like (X|Y) and notepad will find both of these. How can i adress these alternative groups in replace?
      A simplified example: Lets say we want to swap true and false in these lines:
      A candy is true .
      A candy is false .
      A candy is true .
      A candy is false .
      A candy is true .
      Find: (true)|(false)
      I tried using something like \2\1 or \1\2 in replace, but then it does nothing?
      How can i set replace option for each alternative?
      Again, this is only simplified example so 3-step replace is not satisfying :)
      • rinku singhR
        rinku singh
        find what : A candy is .*$
        • Adam ProchowskiA
          Adam Prochowski
          This changes whole subject to a small regex workaround that doesnt work as indented. I Want to have both alternatives and i want to replace based on which alternative is found. So if you find “true” replace with false, if you find “false” replace with true. this is again simplified. Once i get this to work, the alternatives will be contucted of regexes and the replace will be also based on groups i find using regex. I only pinpointed the part i have trouble with - How to adress alternative in find - so that people don’t go into understanding unnecessary commands when question is simple.
          Hope this clarifies the problem.
          • AdrianHHHA
            AdrianHHH
            Try a regular expression replace of
            (A candy is true)|(A candy is false)
            with
            (?1A candy is false)(?2A candy is true)
            See
            https://www.boost.org/doc/libs/1_48_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
            Adam ProchowskiA 1 Reply Last reply Reply Quote 2
            • Adam ProchowskiA
              Adam Prochowski @AdrianHHH
              with
              See
              Thanks! This works :) . I went to this page before but i must’ve misunderstood
              "For example, the format string “(?1foo:bar)” will replace each match found with “foo” if the sub-expression $1 was matched, and with “bar” otherwise. "
              I tried to use it with “:” between alternatives, but that didn’t quite work. Your solution with (?N smg ) works just right.
                A couple of more good references to this technique:
                • https://notepad-plus-plus.org/community/topic/12887/switching-letters-with-one-regex
                • https://notepad-plus-plus.org/community/topic/14157/change-a-word-in-regex
