    Regex partial replacement syntax? Grouping not working
    9 Posts 3 Posters 912 Views
    • Pam RathmellP
      Pam Rathmell
      I have tried both\ and $ to group the strings I’m trying to match and substitute. This syntax works in other text editors, and on the web in a regex tester. This search does find 2008 but it doesn’t replace it properly. Is there a different syntax I should be using, or is there a setting I am missing?
      String to search for
      (\d{4})(<)
      String to search in
      <td>2008</td>
      Replacement String
      <a href=“…/\1/\1.html”>\1</a>\2
      Result
      <td><a href=“…//.html”></a>/td>
      Desired Result
      <td><a href=“…/2008/2008.html”></a>/td>
      • Pam RathmellP
        Pam Rathmell
        I’m using Notepad++ v7.1.1 (64 bit) on a Windows 10 Pro 64 bit computer. brand new user and this is the out-of-the-box vanilla version.
          For me this work with npp7.7.1 on win7 x64.
          It produce the desired output because of the used regex but it does replace 2008.
          Could you post your debug info, which is available under the last menu item, the ? menu ?
          • Pam RathmellP
            Pam Rathmell
            I’m baffled. I did the search/replace this time and it WORKED. I had rebooted in the meantime, perhaps something was cached?
            • Pam RathmellP
              Pam Rathmell
              It works in one file, but not in another. Here’s the debug info:
              Notepad++ v7.7.1 (64-bit)
              Build time : Jun 16 2019 - 21:24:47
              Path : D:\notepad++\notepad++.exe
              OS : Windows 10 (64-bit)
              I also tried copy and paste of the relevant text into a brand new file and that didn’t work either
              Plugins : mimeTools.dll NppConverter.dll
                Ekopalypse @Pam Rathmell
                @Pam-Rathmell
                which checkboxes are actually checked in the find/replace dialog and are you aware
                that when the caret is after the text to be found that only wrap around checked would start searching from
                the beginning?
                • Pam RathmellP
                  Pam Rathmell
                  I ended up using another text editor to make the (massive) changes. But I’d like to know if this is actually a bug?
                  • Pam RathmellP
                    Pam Rathmell
                    Based on your question, I did some more fiddling around. I had “backward direction” and “wrap-around” checked. With these settings, I got a reliable failure. When I changed it to “forward direction” it succeeded. I believe this is a bug and backward direction does not recognize the grouping.
                      Alan Kilborn @Pam Rathmell
                      @Pam-Rathmell
                      Moving in a backward direction is tricky for regular expression engines. It mostly works okay, but it does strange things often enough that even Notepad++ at one time disabled it (searching ‘up’ when the Search mode was Regular expression). That disabling has mostly gone away now it seems.
                      I guess you have stumbled upon one of the odd situations.
                      I wanted to see what Pythonscript’s regular expression replacement function would do with your situation, and in trying to get it working I started with a simpler search, and I discovered that attempting to search backwards, even very simply, gives no matches at all. :(
