    Wrong parsing for C function
    5 Posts 3 Posters 673 Views
    • neacsumN
      neacsum
      I hope the image below is visible and can explain my problem:
      A eth_configure function invocation is shown as a function definition in the function list pane.
      Any clues?
      • MAPJe71M
        MAPJe71
        Clue?
        Attach the source file or a representative snippet so we don’t have to do all the typing.
        Where does the if (ifconfig (... reside? In the body of main (), init (), eth_configure (...) or …?
        • neacsumN
          neacsum
          OK, I narrowed it down to this fragment:
          Seems the problem appears when the function call is in an if statement. The source file can be downloaded from this link.
          This is Notepad++ V7.7.1 (64-bit).
            My guess is that this is related to https://github.com/notepad-plus-plus/notepad-plus-plus/issues/4794 and thus https://github.com/notepad-plus-plus/notepad-plus-plus/issues/4575
            • neacsumN
              neacsum
              Yes, it seems that way. One more thing: if I change the language to C++ the issue goes away. It is probably related to the horrendous regexps used for parsing C function definitions but I’m not smart enough to figure it out.
