    Help, problem with decrypt
    2 Posts 2 Posters 762 Views
    • Џо НиЏ
      Џо Ни
      When i want to decrypt using NPPCrypt, it shows a problem “sadly this header version is no longer supported”, so if it’s some solution to fix this problem please answer ! Thanks !
        See this FAQ from the author of the plugin. You need to install an older NppCrypt (1.0.1.5), then decrypt any files that were encrypted before, then update to the newer 1.0.1.6, then do a new encryption using the new tool.
