    How to start 2. How do I delete blocks of text?
    9 Posts 3 Posters 3.2k Views
    • Mon OnkelM
      Mon Onkel
      Now to my second question: How do I delete blocks of text?
      The text immediately before the block is unique, and also the text immediately after the block. The blocks themselves are from 2 to maybe 50 lines long and starts and ends with the same group of words.
        Ekopalypse @Mon Onkel
        @Mon-Onkel
        I assume a regex could do the job but for this to make it work there is a need to know your data exactly.
          Alan Kilborn @Ekopalypse
          @Mon-Onkel
          So Notepad++ can do a few types of searches, one is a “normal” search where it searches for exactly what you type; a second type of search is called a “regular expression” search. In this 2nd type of search, certain characters that you type have special meaning, for example a . means to match any character, a * means to match the previous thing zero or more times, a ? following a * means to match the previous as few times as possible. Putting it all together, .*? could possibly come between your leading text and your following text.
          So as an example, abc.*?xyz would match any of the following (and many more):
          • abcdefxyz
          • abcdefghijxyz
          • the entire english alphabet, in order
          So perhaps .*? will appear in the middle of what you need, but @Ekopalypse is correct, we need more infos.
          • Mon OnkelM
            Mon Onkel
            ****This is the longest block: ****
            Subject: Phonogram Digest V15 #1
            From: owner-phonogram-digest@phonogram.net (Phonogram Digest)
            Date: Thu, 6 Jan 2011 02:41:43 -0500
            To: phonogram-digest@phonogram.net
            X-Account-Key: account2
            X-UIDL: 1pAKuM2wD3Nl34c0
            X-Mozilla-Status: 0001
            X-Mozilla-Status2: 00000000
            Status: U
            Return-Path: owner-phonogram-digest@phonogram.net
            Received: from noehlo.host ([127.0.0.1]) by mx-stork.atl.sa.earthlink.net (EarthLink SMTP Server) with SMTP id 1pAKuG2wD3Nl34c0; Thu, 6 Jan 2011 02:42:52 -0500 (EST)
            Received: from mail.phonogram.net ([69.20.22.243]) by mx-stork.atl.sa.earthlink.net (EarthLink SMTP Server) with ESMTP id 1pAKuM2rD3Nl34c0 for vinyl1@earthlink.net; Thu, 6 Jan 2011 02:42:52 -0500 (EST)
            Received: (from majordom@localhost) by mail.phonogram.net (8.11.6/8.11.6) id p067fhr30987 for phonogram-digest-outgoing; Thu, 6 Jan 2011 02:41:43 -0500
            Message-ID: 201101060741.p067fhr30987@mail.phonogram.net
            Reply-To: phonogram@phonogram.net
            Sender: owner-phonogram-digest@phonogram.net
            Errors-To: owner-phonogram-digest@phonogram.net
            X-ELNK-AV: 0
            X-ELNK-Info: sbv=0; sbrc=.0; sbf=0b; sbw=000;
            Reply-to: phonogram@phonogram.net
              @Mon-Onkel
              … and what do you want to delete?
              • Mon OnkelM
                Mon Onkel
                Everything from (and including) the first part of the first line Subject: Phonogram Digest
                to (and including) the last line Reply-to: phonogram@phonogram.net
                The text between those two lines are different in each block.
                  @Mon-Onkel
                  for this given example a regualr expression like
                  find what:(?s-i)Subject.*?Reply-to.*?\R
                  replace with is empty
                  would do it BUT this assumes that each block starts with Subject and ends with Reply-to and
                  there is no Reply-to in between.
                  Note, this search is case sensitive, meaning Reply-To and Reply-to is different.
                  Mon OnkelM 1 Reply Last reply Reply Quote 2
                  • Mon OnkelM
                    Mon Onkel @Ekopalypse
                    @Ekopalypse
                    Thank you. That worked with a little editing of the expression to
                    (?s-i)Subject: Phonogram Digest.?Reply-to: .?\R
                      Alan Kilborn @Mon Onkel
                      @Mon-Onkel
                      Another gotcha when posting here is that when you use * it gets turned into an italics font. See that? So the regular expression you posted makes no sense. It should be, AFAICT, (?s-i)Subject: Phonogram Digest.*?Reply-to: .*?\R
                      You can get the special text I just showed by wrapping it in backticks, also known as grave accents.
