    How do i get the Command Help box?
    2 Posts 2 Posters 497 Views
    • jhacker8J
      jhacker8
      Hi i just downloaded the latest version of Zorro on my new computer and when i use Notepad++ i do not have the command help box at the bottom of my screen anymore. For example, i will be using a built in function and normally when i do that it will have the parameters i can use in the command help box down below. How do i get the command help box back?
      If you are able to help me i would really appreciate it.
      cheers.
      andrecool-68A 1 Reply Last reply Reply Quote 0
      • andrecool-68A
        andrecool-68 @jhacker8
        @lhackner
        Maybe a movie session will be a little later)))
