    My plugin does not load in the newest versions
    11 Posts 6 Posters 2.8k Views
    • Andrew CutforthA
      Andrew Cutforth
      My plugin (AJC Active Backup) loads on v5.9 and works fine. On the newer versions it just does not load. I’ve tried moving it to different locations like app data etc but it never loads. Is this likely to be a location problem or has some other thing with compatibility of the dll changed in the newer versions?
        Alan Kilborn @Andrew Cutforth
        @Andrew-Cutforth
        Plugins that used to be directly in the plugins folder now have to be one level down, e.g.:
        ...\plugins\XXX.dll
        needs to go in:
        ...\plugins\XXX\XXX.dll
        • Andrew CutforthA
          Andrew Cutforth
          I tried that. So it is normally:
          C:\Program Files (x86)\Notepad++\plugins\AJCActiveBackupNppPlugin.dll
          So I tried it in:
          C:\Program Files (x86)\Notepad++\plugins\AJCActiveBackupNppPlugin\AJCActiveBackupNppPlugin.dll
          It still does not find it. If I reinstall Notepad++ v7.5.9 it works again.
            Does it give an error message (often through a dialog box), or does it just silently ignore it? There are some plugins that worked with old versions of Notepad++ that don’t work under the new, due to changes in the Notepad++ codebase… but those would generally either load fine but give errors when you try to run one of their actions, or would give an error during the loading of the plugin.
            Are you sure there aren’t any spaces in the DLL name? If there are, there need to be spaces in the path name as well.
            Please supply the Debug Info (? Menu, Debug Info, Copy Debug info into clipboard) on the version that isn’t working. And, if possible, drop to a command prompt in your plugins directory, and give us a directory listing of the plugins directory and the subdirectory. paste into notation like
            dir C:\Program Files (x86)\Notepad++\plugins
            dir C:\Program Files (x86)\Notepad++\plugins\AJCActiveBackupNppPlugin
            to wrap your output, so it renders like:
            This will then make sure that the forum doesn’t mangle what you’re trying to show us.
            • Andrew CutforthA
              Andrew Cutforth
              It does not give any error message, just starts up and my plugin is not loaded.
              Debug info:
              Notepad++ v7.6 (32-bit)
              Build time : Nov 12 2018 - 23:51:42
              OS : Windows 10 (64-bit)
              Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll NppExport.dll
              Folder listings with my plugin in two places
              Directory: C:\Program Files (x86)\Notepad++\plugins
              Mode LastWriteTime Length Name
              d----- 25/07/2019 15:47 AJCActiveBackupNppPlugin
              d----- 25/07/2019 12:36 APIs
              d----- 25/07/2019 12:42 Config
              d----- 25/07/2019 12:36 disabled
              d----- 26/07/2019 10:27 DSpellCheck
              d----- 26/07/2019 10:27 mimeTools
              d----- 26/07/2019 10:27 NppConverter
              d----- 26/07/2019 10:27 NppExport
              -a---- 02/05/2019 10:12 73728 AJCActiveBackupNppPlugin.dll
              Directory: C:\Program Files (x86)\Notepad++\plugins\AJCActiveBackupNppPlugin
                Ekopalypse @Andrew Cutforth
                @Andrew-Cutforth
                do you know ProcMon?
                Set a filter to something like path contains AJCActiveBackupNppPlugin and see what is going on.
                  I do not recommend using that version. Versions 7.6 thru 7.6.2 were in a state of flux in regard to the plugin hierarchy, where they matched neither the old v7.5.9-and-earlier hiearchy or the v7.6.3-and-newer hierarchy. The plugin hierarchy stabilized in v7.6.3, and has stayed the same from then thru the current v7.7.1.
                  • Andrew CutforthA
                    Andrew Cutforth
                    Thanks I thought I was on the latest version. Anyway using ProcMon, Notepad++ v7.6 was finding my plugin here:
                    C:\Users\myname\AppData\Local\Notepad++\plugins\AJCActiveBackupNppPlugin\AJCActiveBackupNppPlugin.dll
                    Now using v7.5.1 it is finding my plugin here:
                    My product AJC Active Backup has the option to install the plugin and copies it to the the plugins folder. So for compatibility for different versions of Notepad++ I suppose I will have to now copy the plugin to both locations:
                    • dinkumoilD
                      dinkumoil @Andrew Cutforth
                      You could also use the Win32 APIs GetFileVersionInfoSize, GetFileVersionInfo and VerQueryValue to query the version number from the file notepad++.exe in order to decide which target directory to choose.
                      I provide you some Delphi code that does the job. You should be able to port that to your preferred programming language.
                      Documentation of the VS_FIXEDFILEINFO struct : https://docs.microsoft.com/en-us/windows/win32/api/verrsrc/ns-verrsrc-tagvs_fixedfileinfo
                      // Enum to specify the type of numeric version info to query
                      TNumericFileVersionInfoTag = (
                        nfvitFileVersion,
                        nfvitProductVersion
                      class function TFileVersionInfo.GetNumericVersionInfo(const FileName: string; const InfoTag: TNumericFileVersionInfoTag; out VersionMajor, VersionMinor, Release, Build: integer): boolean;
                      var
                        dwLen:    DWORD;
                        dwHandle: DWORD;
                        lpData:   pointer;
                        dwBytes:  UINT;
                        FileInfo: PVSFixedFileInfo;
                      begin
                        Result       := false;
                        VersionMajor := 0;
                        VersionMinor := 0;
                        Release      := 0;
                        Build        := 0;
                        dwLen := GetFileVersionInfoSize(PChar(FileName), dwHandle);
                        if dwLen = 0 then exit;
                        GetMem(lpData, dwLen);
                        try
                          if not GetFileVersionInfo(PChar(FileName), dwHandle, dwLen, lpData) then
                            exit;
                          if not VerQueryValue(lpData, '\', pointer(FileInfo), dwBytes) then
                            exit;
                          case InfoTag of
                            nfvitProductVersion:
                            begin
                              VersionMajor := (FileInfo.dwProductVersionMS) shr 16;
                              VersionMinor := (FileInfo.dwProductVersionMS) and $FFFF;
                              Release      := (FileInfo.dwProductVersionLS) shr 16;
                              Build        := (FileInfo.dwProductVersionLS) and $FFFF;
                            end;
                            nfvitFileVersion:
                            begin
                              VersionMajor := (FileInfo.dwFileVersionMS) shr 16;
                              VersionMinor := (FileInfo.dwFileVersionMS) and $FFFF;
                              Release      := (FileInfo.dwFileVersionLS) shr 16;
                              Build        := (FileInfo.dwFileVersionLS) and $FFFF;
                            end;
                          end;
                          Result := true;
                        finally
                          FreeMem(lpData);
                        end;
                      end;
                      • Andrew CutforthA
                        Andrew Cutforth
                        Thanks for your help
                        chcgC 1 Reply Last reply Reply Quote 0
                        • chcgC
                          chcg @Andrew Cutforth
                          @Andrew-Cutforth See https://github.com/notepad-plus-plus/nppPluginList. You may want to provide a zip package which could be installed via PluginAdmin for N++ versions newer than 7.6.3.
