    Invoking python script in plugin method
    8 Posts 4 Posters 1.7k Views
    • Parth KuraniP
      Parth Kurani
      I am using NPPlugins.NET for plugin generation. Right now, I am trying to invoke a python script and pass in the current document into it; however, the script itself does not seem to be executing. Here is the code:
          internal static void GetCurrentDocumentText()
              IntPtr curScintilla = PluginBase.GetCurrentScintilla();
              String s = GetDocumentText(curScintilla);
              string progToRun = "C:\\test.py";
              Process proc = new Process();
              proc.StartInfo.FileName = "C:\\Users...\\python.exe";
              proc.StartInfo.UseShellExecute = true;
              proc.StartInfo.RedirectStandardOutput = false;
              proc.StartInfo.Arguments = string.Concat(progToRun, " ", s)
              proc.Start();
              proc.WaitForExit();
      • rinku singhR
        rinku singh
        proc.StartInfo.UseShellExecute = false;
          Ekopalypse @Parth Kurani
          @Parth-Kurani
          Just curious, you know that there is a python script plugin available, don’t you?
          • Parth KuraniP
            Parth Kurani
            @gurikbal-singh Even when I set useShellExecute to false, the python script is still not being invoked. The txt file that my python script is supposed to generate cannot be found anywhere. Any advice on how to resolve this issue?
            rinku singhR 1 Reply Last reply Reply Quote 0
            • Parth KuraniP
              Parth Kurani
              @Ekopalypse are you referring to PyNPP? If so, it doesn’t have all the capabilities that I would like.
                The Python Script plugin is not PyNPP (which I had not heard of until now). It is a plugin which embeds a full Python 2.7 interpreter inside the Notepad++ environment, and allows you to run a script from within Notepad++ that gives Python direct access to the contents of all the files open in Notepad++, along with access to many aspects of the Notepad++ GUI.
                For instructions on how to install the Python Script in Notepad++ v7.6.3 and later, see this Guide by @Meta-Chuh (because, unfortunately, Python Script plugin doesn’t currently install using the Plugins Admin interface).
                  @Parth-Kurani
                  No, i was referring to the one @PeterJones mentioned.
                  • rinku singhR
                    rinku singh @Parth Kurani
                             try
                                Process Process = new Process();
                                string keyValues = currentDirectory() + "\\User_Command_Line_Tools_PATH";
                                string keyValue = currentDirectory() + "\\GnuWin32\\bin";
                                string envVar = Process.StartInfo.EnvironmentVariables["path"];
                                if (envVar != null)
                                    string value = envVar + ";" + keyValue + ";" + keyValues;
                                    Process.StartInfo.EnvironmentVariables["path"] = value;
                                else
                                    Process.StartInfo.EnvironmentVariables.Add("path", keyValue);
                                    Process.StartInfo.EnvironmentVariables.Add("path", keyValues);
                                Process.StartInfo.FileName = windir() + "\\cmd.exe";
                                Process.StartInfo.Arguments = "/c " + richTextBox1.Text;
                                if (filepath().ToString() == filex().ToString())
                                    Process.StartInfo.WorkingDirectory = currentDirectory() + "\\GnuWin32\\bin";
                                else
                                    Process.StartInfo.WorkingDirectory = path.ToString();
                                Process.StartInfo.RedirectStandardError = true;
                                Process.StartInfo.RedirectStandardOutput = true;
                                Process.StartInfo.RedirectStandardInput = true;
                                Process.StartInfo.UseShellExecute = false;
                                Process.StartInfo.CreateNoWindow = true;
                                Process.Start();
                                string lined = Process.StandardOutput.ReadToEnd();
                                string line = Process.StandardError.ReadToEnd();
                                if (String.IsNullOrEmpty(lined))
                                    richTextBox2.AppendText(line + Environment.NewLine);
                                if (String.IsNullOrEmpty(line))
                                    richTextBox2.AppendText(lined + Environment.NewLine);
                                Process.WaitForExit();
                                if (checkBox2.Checked == true)
                                    Win32.SendMessage(PluginBase.GetCurrentScintilla(), SciMsg.SCI_SETTEXT, 0, richTextBox2.Text);
                            catch (Exception ex)
                                System.Diagnostics.Debug.Write(ex.Message);
