    How to write and execute a replace script by menu/hotkey?
    5 Posts 3 Posters 1.5k Views
    • Claudia SvensonC
      Claudia Svenson
      In many files I have to execute some replacements, e.g. simplified
      replace (all occurrencies of) “aaa” by “bbb”
      replace (all occurrencies of) “2018” by “2019”
      Therefore I would like to
      1. Write a replace script in Notepad++ which contains all these replacement instructions
      2. Load a file
      3. Execute the previously created replace script by (sub)menu or hotkey in NP++
      How can I achieve this in detail?
      Does NP++ offer this feature or is there a Plugin for that?
      andrecool-68A Alan KilbornA 2 Replies Last reply Reply Quote 0
      • andrecool-68A
        andrecool-68 @Claudia Svenson
        @Claudia-Svenson Find and replace in the entire catalog … not suitable?
        Imgur
        • Claudia SvensonC
          Claudia Svenson
          Yes, thats perfect for a one-time replacement.
          But I need this replacement with specific pattern frequently.
          Having to enter it manually in the mentioned dialog every time is uncomfortable.
          So I need a script handling for that.
          andrecool-68A 1 Reply Last reply Reply Quote 0
          • andrecool-68A
            @Claudia-Svenson You need a magic wand … I don’t have one)))
              Alan Kilborn @Claudia Svenson
              @Claudia-Svenson
              You can record a macro for the replacement operation. See the Macro menu – fairly self-explanatory. The macro snapshot happens when one of the buttons is pressed (e.g. Replace, Replace All, etc).
