    No module named Npp
    pythonscript
    32 Posts 4 Posters 7.7k Views
      Alan Kilborn @Alina Gubanova
      @Alina-Gubanova
      I think you are on the right track for running your script now.
      I presume you are trying to run the original script you posted? If that’s the case, I don’t see any reason why a new1 window would be opened. Perhaps you should add some more console.write() statements to the script to attempt to track control flow?
      Alina GubanovaA 1 Reply Last reply Reply Quote 0
      • Alina GubanovaA
        Alina Gubanova @Alan Kilborn
        @Alan-Kilborn Now I just get Traceback (most recent call last): File "C:\...\Notepad++\plugins\PythonScript\scripts\convertutf8.py", line 14, in <module> console.write() Boost.Python.ArgumentError: Python argument types in Console.write(Console) did not match C++ signature: write(class NppPythonScript::PythonConsole {lvalue}, class boost::python::api::object) when I added some console.write()
          Well, from the error message I’d assume that you put console.write() directly in your code. What I mean was to put something like console.write('got here!') at a strategic place or putting a variable name inside the parens, or…just in general some debugging techniques that one might do when programming Python without an IDE.
          Like @guy038, when I run your original script on some test files, it seems to do what you intend.
          I’m assuming you got this working script from a coworker as you hinted before. Perhaps asking him/her for help getting it going is a better path than us trying to help you from afar.
          Alina GubanovaA 1 Reply Last reply Reply Quote 2
          • Alina GubanovaA
            @Alan-Kilborn Okay, will do! Thank you again!
              Hello, @alina-gubanova,
              I don’t really understand why you cannot get it straight. It should be practically obvious !
              • Create a folder, outside C\Program files..., on your configuration
              • Install a recent portable N++ version by extracting the archive’s contents inside this folder
              • Install a recent PythonScript release, by extracting the archive’s contents inside this folder
              • Verify that the tree structure, of this new installation folder of N++, is like in my previous post
              • Open Notepad++
              • Select the option Plugins > PythonScript > New Script
              • Enter a name for your script, let’s say Alina and click on the Save button
              => A new tab, Alina.py is, then, displayed
              • Paste the contents of your script, below, changing, of course, the value of the filePathSrc variable
              import os;
              import sys;
              import Npp;
              from Npp import notepad
              filePathSrc="X:\\xxxxxxxxxxxxt" # Path to the folder with files to convert
              for root, dirs, files in os.walk(filePathSrc):
                  for fn in files:
                      if fn[-4:] == '.txt':
                           notepad.open(root + "\\" + fn)
                           console.write(root + "\\" + fn + "\r\n")
                           notepad.runMenuCommand("Encoding", "Convert to UTF-8")
                           notepad.save()
              notepad.close()
              • Save the Alina.py Python file
              • Close and restart Notepad++ ( IMPORTANT as your script will be found, inside the Python files list)
              • Choose the option Plugins > PythonScript > Show Console, just to visualize possible errors
              • Then, run your script, by selecting the option Plugins > PythonScript > Scripts > Alina
              => The absolute paths of all the files of your folder should be displayed on the Python console
              Done ! Here we are ;-))
              Alina GubanovaA Alan KilbornA 2 Replies Last reply Reply Quote 1
              • Alina GubanovaA
                Alina Gubanova @guy038
                @guy038 Once again, I appreciate your time commitment and input into this issue. I too find it frustrating that I cannot get such an easy thing to work, and as you can see I obviously do not have much experience working with N++. I assure you, from what I am looking at, I have performed all of the steps that you have described correctly, but I will make sure to reinstall the newer version of n++ in case something went wrong during installation.
                  Alan Kilborn @guy038
                  @guy038 said:
                  I don’t really understand while you cannot get it straight. It should be practically obvious !
                  Maybe a tad harsh. A reinstall of things is definitely not easy given the current state of things with the Pythonscript plugin. But…to me it sounded like the OP had PS installed correctly from the beginning, just the approach to running a script was wrong. That all being said, it is tough to determine currently what is going wrong.
                  • Alina GubanovaA
                    Alina Gubanova
                    @Alan-Kilborn @guy038 Issue fixed. Changed filePathSrc= "some directory" to filePathSrc= r"somedirectory"
                    and everything worked fine.
                      @Alina-Gubanova
                      Of course, we could have never debugged THAT from here. :)
                      Alina GubanovaA 1 Reply Last reply Reply Quote 3
                      • Alina GubanovaA
                        @Alan-Kilborn yep :) well, thanks for your help!
