    Emmet: Python Script Plugin not found
    4 Posts 3 Posters 1.3k Views
    • dragonmenorkaD
      dragonmenorka
      When I try to do the abreviation div.class, it appears.I’ve got PythonScript Plugin installed as PythonScriptPlugin.
      App: Notepad+ + (32-bit)
      System: Windows 10 Pro (64-bit)
      EkopalypseE andrecool-68A 3 Replies Last reply Reply Quote 0
        Ekopalypse @dragonmenorka
        @dragonmenorka
        please provide the debug-info from the ? menu (the last menu item).
        • andrecool-68A
          andrecool-68 @dragonmenorka
          @dragonmenorka Check for hotkey conflicts! You have 100% conflicts of hotkeys of the plugin Emmett and Scintilla, Notepad ++
          • andrecool-68A
            @dragonmenorka Check the correct directory structure of the installed plugin “Python Script”:
            https://notepad-plus-plus.org/community/topic/17777/python-script-support-in-versions-of-npp-7-9-2/2
            https://notepad-plus-plus.org/community/topic/17256/guide-how-to-install-the-pythonscript-plugin-on-notepad-7-6-3-7-6-4-and-above
