    Compare Plugin v2.0 updated for Notepad 7.7 and above
    37 Posts 16 Posters 44.0k Views
      Ekopalypse @汪Jerrie
      @汪Jerrie
      use plugins admin from plugin menu.
      • vjs-xxV
        vjs-xx
        I recently updated to 7.7.1 (64-bit) and for me the synced scrolling broke too.
        In looking at the View Menu …
        Before starting a compare :-
        both Synchronize Vertical Scrolling and Synchronize Horizontal Scrolling are greyed out.
        When compare opens :-
        Synchronize Vertical Scrolling is UNCHECKED
        Synchronize Horizontal Scrolling is CHECKED
        Behaviour is consistent with these settings.
        Checking the Synchronize Vertical Scrolling option restores the pre-upgrade normal synchronized scrolling
        I cannot see any way to make that setting stick. If I evit Compare, and then restart it, the setting is lost.
        vjs-xxV 1 Reply Last reply Reply Quote 0
        • vjs-xxV
          vjs-xx @vjs-xx
          Having read the comments about and old and a new plugin, I checked the plugins directory and found that the ComparePlugin.dll file was dated from February 2019.
          I used the Plugin Admin to remove the Compare Plugin, and after Notepad+ restarted, I used the Plugin Admin to add back the Compare Plugin again. The new DLL is dated from July 2019.
          Now, the scrolling works as expected (notwithstanding that the Synchronize Vertical Scrolling option is still unchecked)
          So, it seems like the updater is not checking and updating the Compare Plugin if it is already installed. Perhaps the issue is that both versions are labeled as version 2 and it cannot detect the change.
          • pnedevP
            pnedev
            @vjs-xx ,
            That’s the normal behavior of the vertical scroll setting in the menu when comparing.
            Compare plugin does vertical scrolling on its own and it disables the Notepad++ internal one.
            You are right, the plugin doesn’t update on its own because the Compare versions are the same.
            • BuddlerB
              Buddler
              When I compare two files beeing 66 MB, the compare plugin will freeze / stop comparing after reaching maybe 40 %.
              Is there any limit?
              RAM and other memory looks good / still has plenty of ressources.
              • pnedevP
                pnedev
                @Buddler ,
                In some cases compare might take considerable time.
                I don’t know if that’s your case but try waiting some time.
                • igitthatalotI
                  igitthatalot
                  had this problem after updating to 7.8.1. was working fine on 7.5.8.
                  installing the plugin from https://github.com/pnedev/compare-plugin/releases to C:\Program Files\Notepad++\plugins\ComparePlugin replacing the dlls that were there has solved the scrolling problem.
                  I noticed a while ago that compare plugin no longer shows up in the repository of plugin updates. can that be corrected? as it would be nice to just select it from a list rather than having to push files to every machine.
                  • pnedevP
                    pnedev
                    @igitthatalot ,
                    Were you upgrading Notepad++ from v7.5.8 to v7.8.1?
                    If that’s the case the plugin handling since 7.5.8 has been changed. The Plugin Manager is no longer used and in its place now is the Plugin Admin. Start Notepad++ and select from the menu Plugins -> Plugins Admin....
                    You can select and install any plugins you need from there.
                    igitthatalotI 1 Reply Last reply Reply Quote 2
                    • igitthatalotI
                      igitthatalot @pnedev
                      Well whatever you want to call the ‘way to administrate plugins’ the result is the same. There is no compare plugin listed.
                        Ekopalypse @igitthatalot
                        @igitthatalot
                        it is visible under Available tab but only unless you install it
                        Once you installed it, it is visible under Installled tab.
                        • G_Shank17G
                          G_Shank17
                          having problem with installing the compare plugin. when i restart notepad++ it gives me an error compare plugin is not compatible cannot load 32 bit plugin
                            Ekopalypse @G_Shank17
                            @G_Shank17
                            this normally happens if you try to install a 32bit plugin but using the 64bit npp version.
                            Use plugin admin to install it as it will download the correct version.
                            • tjpsnjT
                              tjpsnj
                              Soooo…
                              Can someone just say how to manually install the 64bit plugin with ComparePlugin.dll git2.dll and sqlite3.dll?
                              I just need it to work inside a closed network. Not to mention the manager does not work on a test machine that can.
                              Thanks if you can save me the time.
                              Tom
                              pnedevP 1 Reply Last reply Reply Quote 0
                              • pnedevP
                                pnedev @tjpsnj
                                @tjpsnj ,
                                Please read this:
                                https://github.com/pnedev/compare-plugin/issues/225 .
                                Tell me if you still have problems.
                                • Robert WernerR
                                  Robert Werner
                                  I am unable to get the compare plugin to work at all. Using v 7.8.4 and have checked the compare box. I see a download, but nothing happens (no download). I tried the link in this blog and still can’t see the plugin as an option when I unzip and move it into notepad + +\plugins. Any help appreciated.
                                  PeterJonesP pnedevP 2 Replies Last reply Reply Quote 0
                                    PeterJones @Robert Werner
                                    @Robert-Werner ,
                                    You asked about that over here already. Please don’t ask about the same issue in multiple threads; it makes it hard to follow.
                                    You need some patience; we aren’t paid 24/7 support; we are fellow Notepad++ users who come on this forum voluntarily to help other Notepad++ users; some are on European time, some are on US Pacific coast time, so the hours we will be around vary; and most of us have day jobs and lives outside of work that make responding to forum posts not the hightest priority; waiting 2-4 hours is not unreasonable
                                    I will respond to details in your original thread.
                                    • pnedevP
                                      pnedev @Robert Werner
                                      @Robert-Werner ,
                                      Read here:
