    Bookmarks not saving
    17 Posts 6 Posters 4.9k Views 2 Watching
    • Billy NairB Offline
      Billy Nair
      Back in the old days (a week or so back) when you saved, closed, reopened NPP, your bookmarks (Ctrl+F2) were still there. They stayed there, in the document, until you closed the actual document (vs just closing NPP or rebooting the computer)
      What changed? and can we get it back to where they stayed in the document after you closed NPP?
        Alan Kilborn @Billy Nair
        @Billy-Nair
        Maybe some good reading for you here.
          Alan Kilborn @Alan Kilborn
          Actually, I guess I read the OP wrongly. Anyway, when I set some bookmarks, quit N++, then come back in, my bookmarks are still there. N++ 7.7.
          • EkopalypseE Offline
            mine too :-)
              Billy Nair
              so, you guys are not seeing this?
              NPP v7.7 (32-bit)
                Ekopalypse @Billy Nair
                @Billy-Nair
                no, it is working fine here. What might be the issue is that something has corrupted
                your config.xml file.
                You could temporarily rename it, start npp and see if bookmarks are saved again if when doing another npp restart.
                If you don’t know which config.xml needs to be edited, post your debug-info from ? menu.
                  Billy Nair
                  I wonder if that is the problem, I dont have any config.xml files in any folder…
                  Notepad++ v7.7 (32-bit)
                  Build time : May 19 2019 - 13:08:20
                  OS : Windows 7 (64-bit)
                  Plugins : DSpellCheck.dll FingerText.dll HTMLTag_unicode.dll mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll
                    @Billy-Nair
                    because of your debug-info you should see a config.xml in %AppData%\Roaming\Notepad++ which expands to something like
                    C:\Users\YOUR_USERNAME\AppData\Roaming\Notepad++
                    If npp can’t find its config.xml, it will recreate it.
                      Billy Nair
                      cool, thank you!
                        As a reminder, this FAQ explains that %AppData% includes the Roaming when it expands. The easiest way to verify if you’ve got your %AppData%\... path correct: paste your path in Explorer’s location, and see whether it goes to the right location.
                          Ekopalypse @PeterJones
                          @PeterJones - great, thanks for reminding me. Good job!! :-)
                          • Memo RandomM Offline
                            Memo Random
                            Yes, I am seeing this, too with one file but not others. That is, I quit Notepad++, then re-open it. Nearly all the files have their bookmarks intact as usual, except one file that has lost its bookmarks
                            Alan Kilborn: the link you posted is for a different issue. The original poster on this thread specifically described >expected< behavior wherein you close a file, then re-open it within a session of Notepad++ and the bookmarks are gone. And described >unexpected< behavior where you quite Notepad++, then run it again, and have now lost bookmarks. The thread you linked to has someone having a problem with losing bookmarks when closing a file, then opening it again, which is how Notepad++ has always behaved.
                              Alan Kilborn @Memo Random
                              Right. That’s why I followed it up with:
                                Memo Random
                                Version 7.7 32-bit.
                                Was not a problem with my prior version, 7.6.6.
                                • mike sobota184M Offline
                                  mike sobota184
                                  Notepad++ v7.7 (64-bit)
                                  OS : Windows 10 (64-bit)
                                  … the same! After the Update from v7.6.6 to v7.7 - the bookmarks are gone, if I close n++.
                                  But only if the file is stored on a USB device. If a file is saved locally, the bookmarks remain in their position.
                                  Was not a problem with the prior version, 7.6.6.
                                  Where is the problem? What can I do?
                                  Hopefully the bug will be fixed in the next update.
                                    Memo Random
                                    In my case, the files that lose bookmarks are on a fixed SSD partition along with most of the other files that do not lose their bookmarks. No USB storage involved.
                                    I think the problem has to do with file sizes.
                                    Of the files I have open, four of them lose their bookmarks when exiting, then re-opening Notepad++. These files have the following line counts: 280980, 416104, 434832, 581174.
                                    On the other hand, three files with smaller line counts do not lose their bookmarks: 105223, 158791, 296381.
                                    Since there is some overlap in the ranges of line counts (that is, a file with 296k lines doesn’t lose bookmarks, but a file with 281k lines does lose bookmarks), I suspect the total size of the file (rather than number of lines) is related to the bookmarks getting cleared.
                                      Memo Random
                                      Correction: the above numbers were “length” counts, not line counts. There may be some correspondence between file size and losing bookmarks, but it isn’t a straightforward cause-and-effect.
