    NppExport plugin - 'copy HTML to clipboard' does not work anymore
    16 Posts 14 Posters 11.2k Views
    • Rohan GopalR
      Rohan Gopal
      Hi, I updated NotePad++ recently and now the NppExport plugin does not work correctly anymore (copy HTML to clipboard) … previously i could select text that was set to XML language (with colours etc.), and copy and paste this into word doc (with colours etc.) … now the same copy/paste does not have any colour etc.
      PLEASE advise soonest. thanks
      I am using Notepad++ v7.7 (64 bit), build time: 19 May 2019 13:05:35
      and using NppExport plugin v0.2.8
      • James RinglandJ
        James Ringland
        Similar experience with Notepad++ v7.7 (32 bit) using Export to HTML. It’s not putting in the tags. Reversion to 7.6.4 fixed issue for now.
        • Frank OrellanaF
          Frank Orellana
          Same here on 7.7, still works fine in 7.6.x, if you really have to, downgrade or switch to vscode to copy with format until this get resolved.
            @Rohan-Gopal , @James-Ringland , @Frank-Orellana,
            The biggest change in Notepad++ v7.7 was the switch from Scintilla 3.56 to 4.1.4 as the underlying editor. My guess is that the drastic changes in Scintilla has messed up some existing plugins by changing some required calls to perform specific editor tasks. I thought I remembered a recent post giving more details, but cannot find it with a quick search.
            @Meta-Chuh ,
            Do you remember which post I’m vaguely remembering? Or do you have other insight , like whether my theory about the Scintilla changes as the cause of these users’ NppExport difficulty? Or is there something else that’s a more likely culprit?
            • Meta ChuhM
              Meta Chuh moderator @PeterJones
              i think it was an @Ekopalypse post, but i’m not sure.
              i also have too little knowledge about the scintilla functions used by nppexport.
              and i do not have a clue why copy html to clipboard does not copy anything, while export to html as a file, at least saves the unhighlighted text.
              note: @chcg has nppexport at his repo, in case anyone want’s to have a look at the code, and/or contribute.
              best regards.
              • Jon PeltierJ
                Jon Peltier
                NppExport: ‘Copy RTF to Clipboard’ and ‘Export to RTF’ both maintain font name, size, and bold, but not font color.
                Rohan GopalR 1 Reply Last reply Reply Quote 2
                • Rohan GopalR
                  Rohan Gopal @Jon Peltier
                  @Jon-Peltier colour makes a HUGE difference in readability, so this hopefully gets fixed soon.
                  • Abhinav BhandawatA
                    Abhinav Bhandawat
                    Confirm. NppExport Plugin, doesnt work with both 32 bit & 64. bit Notepad++ Ver 7.7
                    Temporary solution: use the version 7.6.6 and everything works well.
                    • chcgC
                      chcg
                      Created release https://github.com/chcg/NPP_ExportPlugin/releases/tag/0.2.9.21 which is compatible with 7.6 and 7.7.
                      Gia JgarkavaG camill01C Carl WitthoftC 3 Replies Last reply Reply Quote 3
                      • Gia JgarkavaG
                        Gia Jgarkava @chcg
                        @chcg This works perfectly, Thanks!
                        • Rex ArulR
                          Rex Arul
                          Yes, mine is v.7.7.1 and had this problem, until, I downloaded this fix. It works like a charm (as it used to before).
                          • camill01C
                            camill01 @chcg
                            @chcg Awesome! Thanks so much!
                            • Aman S. AnejaA
                              Aman S. Aneja
                              Hi @chcg,
                              Works like a charm.
                              When are you going to release it through the Plugin Manager?
                              Regards,
                              Aman
                              • Eric OsmanE
                                Eric Osman
                                Yes, it works great! Would be wonderful if it just plain worked in notepad++ without having to expand the zip, copy the nppexport.dll to my notepad++/plugins/nppexport folder, and restart notepad++. Any chance of that happening soon? Thanks. /Eric 29-aug-2019
                                • Carl WitthoftC
                                  Carl Witthoft @chcg
                                  @chcg this new version does not appear to work with Npp ver 7.7, 32 bit, under Windows 10.
                                  chcgC 1 Reply Last reply Reply Quote 0
                                  • chcgC
                                    chcg @Carl Witthoft
                                    @Carl-Witthoft What exactly is not working? Which version of the plugin do you use?
                                    Since https://github.com/notepad-plus-plus/nppPluginList/commit/c85225bb5272e8e0dc7f5e36ba1acfbdd7ff0fba -> tag 1.1.3 used by N++ 7.8.1 the plugin is avialable via the builtin pluginAdmin of N++.
