    Is there any plugin for jumping to a function definition when double click on its name?
    6 Posts 4 Posters 3.8k Views 1 Watching
    • Công Cà CuốngC Offline
      Công Cà Cuống
      Hi everyone,
      I have used Notepad++ 7.6.6 32bit on Windows 10 as C-lang editor.
      I want that: double click on a function name (any where on code), then we go to its definition.
      Is there any plugin do this? If not, can some one develop once, please ?
      • Alan KilbornA Online
        Alan Kilborn @Công Cà Cuống
        @Công-Cà-Cuống
        I think you want one of the “tagging” plugins.
        Double-clicking is rather a core editing feature to select the current word, so you may not find that exact functionality.
        • gstaviG Offline
          gstavi
          The main 2 plugins I am aware of are TagLEET (I am its author) and NppGTags. There may be a few others as well.
          TagLEET does not generate the tags file by itself you will need to generate it by running ctags from command line.
          Alan KilbornA 1 Reply Last reply Reply Quote 5
          • Michael VincentM Offline
            Michael Vincent
            I use TagLEET and TagsView if you want a graphical dockable thingie. TagLEET is nice though with a quick shortcut. I put a “Create Tags” shortcut in my Run menu in N++ and run that on a file in the root of my project than all tags are accessible.
              Alan Kilborn @gstavi
              Then you are the right person to ask this of: What is the “LEET” part supposed to mean?
              • gstaviG Offline
                gstavi
                I needed some name with TAG in it.
                Taglit in hebrew (תגלית) is “Discovery”.
                And LEET is associated to Elite.
                So I combined them.
