    How Can I Remove Vertical Scrollbar using LuaScript?
    2 Posts 2 Posters 856 Views
    • hcedH
      hced
      I have the LuaScript plugin installed and am trying to set VScrollbar to false. How do I go about writing this in Lua?
      (Reason for asking is that I’m trying to only show the Document Map… and I’m pretty weak in programming.)
        Hello, @hced and All,
        Welcome to the Notepad++ Community !
        Very simply, indeed !
        • Open the Lua console ( Plugins > LuaScript > Show Console
        • Inside the bottom line, type the command :
        editor.VScrollBar = false with that exact case
        Either, hit the Enter key or click on the Run button
        Here we are !
