    12-hour to 24-hour clock conversion
    21 Posts 5 Posters 3.9k Views
      Hi, all,
      As the (?...:....) regex structure, of the Boost regex library is not so common, you may feel a bit lost about the replacement regex syntax !
      So, here is, below, the algorithmic translation of the replacement regex, of my previous post :
      If group 13 exists    #  Case hour = '12'
          then
              If group 17 exists    #  String 'AM' or 'am', after the digits
                  then
                      Write the string '00'
                  else
                      Rewrite the group 1 contents    #  Actually, the hour '12'
          else
                  then
                      Rewrite the group 1 contents    #  The 'hour' digits, so the values  '01'  or  '02'  or  ...... '11'
                  else    #  The 'hour' digits, when followed with the string 'PM' or 'pm'
                      If group  2 exists then write the string '13'    #  Case hour = '01'
                      If group  3 exists then write the string '14'    #  Case hour = '02'
                      If group  4 exists then write the string '15'    #  Case hour = '03'
                      If group  5 exists then write the string '16'    #  Case hour = '04'
                      If group  6 exists then write the string '17'    #  Case hour = '05'
                      If group  7 exists then write the string '18'    #  Case hour = '06'
                      If group  8 exists then write the string '19'    #  Case hour = '07'
                      If group  9 exists then write the string '20'    #  Case hour = '08'
                      If group 10 exists then write the string '21'    #  Case hour = '09'
                      If group 11 exists then write the string '22'    #  Case hour = '10'
                      If group 12 exists then write the string '23'    #  Case hour = '11'
             endif
      endif
      Write the string ':'
      Rewrite the group 14    #  Minutes digits
      Rewrite the group 15    #  Seconds digits
      if group 16 exits       #  Milleseconds digits
          then
              write the string ':'
              write the group 16 contents    # Milleseconds digits
      endif
