    Session and favorites deleting issue
    9 Posts 3 Posters 2.8k Views
    • Muhamed ZecirovicM
      Muhamed Zecirovic
      Hi,
      If I tried to delete session or favorites from explorer window I got errors. I tried to reinstall n++ even in portable and still has the same issue. Though I can delete manually inside favorite.dat file with no problem.
      Thanks!
        Alan Kilborn @Muhamed Zecirovic
        @Muhamed-Zecirovic
        It might be helpful to tell what the errors actually said, or provide a screenshot. “I got errors” isn’t going to inspire anyone to spend time thinking about what happened to you.
          Muhamed Zecirovic
          Yup you have a right. I’m sending a 2 screenshots.
          this is screenshot before I deleted items inside favorites window
          this is screenshot after I deleted one item in favorite window
            Muhamed Zecirovic
            I tried just now with old Npp 7.0 portable, and cannot see that issue.
              Muhamed Zecirovic
              I finally check all latest versions. This issue exist only in version 7.6.6. for portable (and desktop), I cannot see it in 7.6.4. and earlier
                Ekopalypse @Muhamed Zecirovic
                @Muhamed-Zecirovic
                for me it looks like it is a 64bit problem. The 32bit version and 7.6.6 32bit is working fine here. Every 64bit version I’ve tested showed this error.
                Muhamed ZecirovicM 1 Reply Last reply Reply Quote 1
                  Muhamed Zecirovic @Ekopalypse
                  @Ekopalypse I’m using 32bit, and see this error only in 7.6.6. Temporary I switched to portable 32bit 7.6.4. and it works perfect!
                    @Muhamed-Zecirovic
                    I guess I see - when I start deleting from top to bottom it works but
                    when I start deleting from bottom to top or within the middle then I see the same issue.
                    In both version 32bit and 64bit.
                    Can you confirm? If so, then you might open an issue here.
                      Muhamed Zecirovic
                      @Ekopalypse Yes I confirm that only happened if I delete from bottom to top. I opened issue on github. Thanks!
