    Project panel does not pop up
    project panel
    8 Posts 2 Posters 1.3k Views
    • Pierre HuybensP
      Pierre Huybens
      Good afternoon ,
      in my Office environment they upgrade to notepadd++ 7.6.6 32 bits. Since the upgrade, when I try to open a project panel nothing happen, the project docking window does not appear anymore. I have all my useful files in project 1. I try to open project 2 or 3 but same no windows appear.
      How to add information log/debug to understand why this happen ?
      this feature is so useful, I use it also at home with the same version and this one is working perfectly.
      Thanks a lot.
        Ekopalypse @Pierre Huybens
        @Pierre-Huybens
        would you mind posting the debug-info?
        It is available under ? menu and would reveal how npp is setup and where to look for
        configuration files etc.
        • Pierre HuybensP
          Pierre Huybens
          here is the information. thanks for helping.
          Notepad++ v7.6.6 (32-bit). I just copy back the XML tools that working fine.
          Build time : Apr 3 2019 - 23:49:50
          OS : Windows 10 (64-bit)
          Plugins : mimeTools.dll NppConverter.dll NppExport.dll XMLTools.dll
            @Pierre-Huybens
            because of Local Conf mode : OFF your configuration files are located under
            %APPDATA%\notepad++ (in reality something like C:\Users\YOUR_USERNAME\AppData\Roaming\Notepad++).
            There should be a file called config.xml in it.
            This xml should have an xml tag like
                <ProjectPanels>
                    <ProjectPanel id="0" workSpaceFile="C:\Users\eren\AppData\Roaming\Notepad++\npp_projects" />
                    <ProjectPanel id="1" workSpaceFile="" />
                    <ProjectPanel id="2" workSpaceFile="" />
                </ProjectPanels>
            Can you check if this is the case?
            Can you copy the content of that tag.
            Note, to inculde it like I did use 3 ~ in front and after the text, like
            xml data
            • Pierre HuybensP
              Pierre Huybens
              here is the contain of the file
                 <ProjectPanels>
                   <ProjectPanel id="0" workSpaceFile="C:\cs-coe\workspace2.xml" />
              </ProjectPanels>
              ~~~ xml data ~~~
              and the full file contains point to my project contains , I have  used this one for a while and also sorte to have file  in alphabetic order
              C:\Users\phuybens>dir C:\cs-coe\workspace2.xml
              Volume in drive C is System
              Volume Serial Number is BEC0-4DC3
              Directory of C:\cs-coe
              05/15/2019  03:32 PM             6,005 workspace2.xml
                             1 File(s)          6,005 bytes
                             0 Dir(s)  198,528,884,736 bytes free
              and there is no error in the xml file , I can provide the contains , but when open in notepadd++ there is no xml error  ;-)
              thanks for your help
              • Pierre HuybensP
                Pierre Huybens
                @Ekopalypse : what I do not understand that if i try to open another project (the other empty one) there is also not pop up windows. No wait to start Notepad++ with debug information ?
                  @Pierre-Huybens
                  no, npp doesn’t have something like a log file to see what is going on.
                  Because you mentioned that none of the panels appears I thought the tag got corrupted
                  but doesn’t look like this is the case.
                  What you can try is to stop npp and rename config.xml.
                  When starting npp it will create a default one. Does this work?
                  • Pierre HuybensP
                    Pierre Huybens
                    @Ekopalypse : Yes, this was the solution, Now the Workspace windows is pop up again.
                    Many many thanks Ekopalypse.
