    Where are my plugins? How can I activate my own plugins?
    4 Posts 3 Posters 930 Views
    • Ollo HeßO
      Ollo Heß
      HELP ME PLEASE!
      I just updated to Notepadd++ 7.6.6 (32 bit). Now my plugin won’t be found.
      I wrote myself a plugin DLL, it worked very fine all the time. Now, after the update, it’s no longer active.
      I placed the DLL to the plugins path -> C:\Program Files (x86)\Notepad++\plugins
      • andrecool-68A
        andrecool-68
        Create a directory with the name plugin
        plugins\plugin_name
        • dinkumoilD
          dinkumoil @Ollo Heß
          @Ollo-Heß
          Since Notepad++ v7.6 the plugin management system has undergone some changes. In v7.6.3 and above every plugin needs to be moved to a separate folder under <Notepad++-install-dir>\plugins which has to be named like the plugin’s DLL file itself.
          Example: If a plugin’s DLL file name is ABC.dll it has to be copied to <Notepad++-install-dir>\plugins\ABC.
          Please note: If a plugin needs some companion files mostly they need to be copied to that folder too. If these companion files have been located in e.g. <Notepad++-install-dir>\plugins\doc they have to be moved to <Notepad++-install-dir>\plugins\<Plugin-name>\doc, i.e. the former folder structure has to be kept. Sometimes, depending on the plugin, that even means that the folder <Plugin-name> has to be doubled, i.e. <Notepad++-install-dir>\plugins\<Plugin-name>\<Plugin-name>.
          Some plugins use hard coded access paths to their companion files, thus they will not find them at the new location. In that case the companion files have to stay at their old location (where they have been stored in Notepad++ versions prior to v7.6).
          • Ollo HeßO
            Ollo Heß
            Thank you very much!
