    How to Build and Run Solution in Visual Studio from GitHub
    visual studio
    2 Posts 2 Posters 544 Views
    • rmutalikR
      rmutalik
      Hi,
      I want to contribute code to Notepad++. I synced the repo from GitHub into Visual Studio, but I am not sure how to build the solution. I tried building the solution, but I got a lot of errors, which shouldn’t be happening since I forked the master branch.
      Which files do I need and don’t I need a main() function to run? The only one I found is in x.cpp, but I am not sure how to run that either.
      Thanks.
      • Meta ChuhM
        Meta Chuh moderator @rmutalik
        welcome to the notepad++ community, @rmutalik
        it is best to conduct a community search to get started.
        you will find everything you need.
        example: https://notepad-plus-plus.org/community/topic/13959/building-notepad-with-visual-studio-2015-2017
        best regards.
