    Help for mass replacement.
    mass replacemenhelp
    2 Posts 2 Posters 477 Views
    • Владимир АнтониковВ
      Владимир Антоников
      Hello.
      I need help!
      There is a design type:
      <a href=“/wp-content/uploads/2018/10/2-2.jpg”><img src=“/wp-content/uploads/2018/10/2-2.jpg” alt=“Ergobag1111” width=“1000” height=“708” class=“aligncenter size-full wp-image-21814” /></a>
      <a href=“/wp-content/uploads/2018/10/3-2.jpg”><img src=“/wp-content/uploads/2018/10/3-2.jpg” alt=“Ergobag2222” width=“1100” height=“652” class=“aligncenter size-full wp-image-21815” /></a>
      <a href=“/wp-content/uploads/2018/10/4-2.jpg”><img src=“/wp-content/uploads/2018/10/4-2.jpg” alt=“Ergobag3333” width=“1200” height=“497” class=“aligncenter size-full wp-image-21816” /></a>
      We need to redo it into the next view:
      <a href=“/wp-content/uploads/2018/10/2-2.jpg” class=“item” style=“background-image: url(‘/wp-content/uploads/2018/10/2-2.jpg’)” data-alt=“Ergobag1111” ></a>
      <a href=“/wp-content/uploads/2018/10/3-2.jpg” class=“item” style=“background-image: url(‘/wp-content/uploads/2018/10/3-2.jpg’)” data-alt=“Ergobag2222” ></a>
      <a href=“/wp-content/uploads/2018/10/4-2.jpg” class=“item” style=“background-image: url(‘/wp-content/uploads/2018/10/4-2.jpg’)” data-alt=“Ergobag3333” ></a>
      I tried to make it a team:
      (“><img src=”)|(" width=“." height=".” class=“.* /></a>)|(” width=“." height=".” class=".* /></a>)
      (?1" class=“item” style=“background-image: url(‘)(?2’)” data-alt=“)(?3” ></a>)
      But it does not work correctly.
      I want to do exactly that the replacement occurred as a team.
      Please, help!
        Hello, владимир-антониковn, and All,
        Assuming that your XML text uses :
        • Regular Simple quote ( ' ), of Unicode value \x{0027}, and not the characters ‘ and ’
        • Regular Double quote ( " ), of Unicode value \x{0022}, and not the characters “ and ”
        These changes of text can be easily done with regular expressions :-))
        • SEARCH ><img src="(.*?)"\x20(alt=".+?").+?\x20/(></a>)
        • REPLACE \x20class="item"\x20style="background-image:\x20url\('\1'\)"\x20data-\2\x20\3
        • Tick, preferably, the Wrap around option
        • Click, once on the Replace All button or several times on the Replace button
        Et voilà !
        If OK, I’ll give you some explanations on that regex S/R, next time
        Best Regards
