    I need help
    2 Posts 2 Posters 663 Views
    • Andrew MessierA
      Andrew Messier
      I have a file that I need to code in but I don’t know what language to pick at the end it has .vtt and I have a windows computer
        Terry R
        If you were to check the web you would have likely found it is most likely a Web Video Text Tracks File. See https://fileinfo.com/extension/vtt
        It is a text file, however I would suggest you need the appropriate editor to edit/create this type of file.
        Notepad++ is designed to edit text files, however it doesn’t necessarily understand the correct formatting of data within each file, so using it would IMO likely create a bad file.
