    That mysterious ESCAPE box - UDL
    2 Posts 2 Posters 972 Views
    • Randy DiCottiR
      Randy DiCotti
      What is the ESCAPE box for in the UDL Delimiter styles?
      Downloaded all the Documentation I could find and have yet to see an explanation.
      • Meta ChuhM
        Meta Chuh moderator @Randy DiCotti
        @Randy-DiCotti
        it defines escape characters, which disable a delimiter
        for example if you have " as start and end, but you want to write it in the middle without breaking the highlighting, you can “escape” this character or sequence with another preceeding character, usually \.
        more info: https://udl20.weebly.com/delimiters.html
