    What's the script for compiling and running C/C++ in Notepad++ 7.6.3
    9 Posts 4 Posters 4.4k Views 2 Watching
    • Abdelrahiman SolimanA Offline
      What’s the script in NPP_EXEC for compiling and running C/C++ in Notepad++ 7.6.3.
        Alan Kilborn @Abdelrahiman Soliman
        @Abdelrahiman-Soliman
        That greatly depends upon which C/C++ toolset you are using.
        Abdelrahiman SolimanA 1 Reply Last reply Reply Quote 0
        • dinkumoilD Offline
          dinkumoil
          Have a look at my Script Collection code repository under NppExec Scripts -> Compile_&_Run.
          There I use Tiny C Compiler for compiling C programs. You have to adapt my script to the toolset you actually use for C/C++ development. Maybe you want to shorten it as well.
            Abdelrahiman Soliman @Alan Kilborn
            Whats the toolset? I am using Cygwin 64 bit version 3.0.4
            EkopalypseE Alan KilbornA 2 Replies Last reply Reply Quote 0
            • EkopalypseE Offline
              Ekopalypse @Abdelrahiman Soliman
              On windows normally you use Visual C++ compiler toolset but cygwin comes with gcc bundled as far as I know. There are other like mentioned by @dinkumoil, tcc or clang or …
              Each toolset requires it own set of parameters etc… to compile and link different projects.
                So you need to know what the following looks like for your situation:
                • command line to compile a file
                • command line to link project together
                • name of resulting exe from successful link
                Then you can put all this together using @dinkumoil 's example NppExec script, for your specific use case
                Make sense?
                Abdelrahiman SolimanA 1 Reply Last reply Reply Quote 2
                  I am not sure if I understood. Very new to programming. How do I find those three steps? And when I find the three steps what script do I choose from @dinkumoil’s list of scripts, there are about 200 different scripts.
                    So we can’t teach you programming here or what “compiling”, “linking”, etc means here. Because this area is about Notepad++. You need to go off and figure those things out. Then come back here and we can tell you more exactly how to do your stuff under Notepad++ control.
                    But once you figure your end out, and realize that @dinkumoil already told you what area of the script to look at, it is all easy so you may not need more from us here.
                    Abdelrahiman SolimanA 1 Reply Last reply Reply Quote 3
                      Thanks for the preceding helping effort.
