    Notepad 7.6.3 and 7.6.4 / SourceCookifier 0.7.3 / 'ctags.exe' not found!
    8 Posts 4 Posters 2.3k Views
    • ManisselM
      Manissel
      Notepad 7.6.3 and 7.6.4 / SourceCookifier 0.7.3 / ‘ctags.exe’ not found!
      %appdata%\Notepad++\plugins\Config\SourceCookifier.errorlog.txt:
      at SourceCookifier.CTagsExe.Init()
      at SourceCookifier.Settings.LoadSettings(TreeView treeview)
      at SourceCookifier.frmMain…ctor()
      at SourceCookifier.Main.InitFrmMain()
      at SourceCookifier.Main.ShowFrmMain()
      C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\SourceCookifier.dll
      C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\ctags.exe
        I never used this plugin but could it be that ctags.exe must be in the directory where notepad++.exe is?
        • pnedevP
          pnedev
          Hello,
          Try putting ctags.exe in C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\SourceCookifier folder -
          C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\SourceCookifier\ctags.exe .
          • ManisselM
            Manissel
            WORKED! Will test the behavior in daily business.
            Thanks in advance
            • ManisselM
              Manissel
              Folder structure:
              C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\icons
              C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\AddPolicy.bat
              C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\RemovePolicy.bat
              Only moved:
              To:
              Meta ChuhM 1 Reply Last reply Reply Quote 4
              • pnedevP
                pnedev
                @Manissel ,
                I’m not sure but logically all SourceCookifier files except the SourceCookifier.dll should be where the ctags.exe is -
                • Meta ChuhM
                  Meta Chuh moderator @Manissel
                  @Manissel and all
                  if you encounter any further problems with the SourceCookifier plugin and it’s folder structure:
                  (for example because it was already installed, prior to installing notepad++ 7.6.3)
                  • go to your plugins folder.
                  • move the SourceCookifier folder to your desktop.
                    (you can delete it later, if you don’t need any custom files from there)
                  • important note: it is recommended not to remove any plugins using plugins admin, if they have not been installed by plugins admin.
                    (side note: you can distinguish some plugins, if they are not in the official plugins list, as they have the extension .dll in the plugins admin installed list)
                  • install a fresh SourceCookifier 0.7.3 using plugins admin.
                  if SourceCookifier is installed using plugins admin, all plugin files should automatically be deployed to their correct locations of the respective notepad++ version.
                  • ManisselM
                    Manissel
                    Clean installation / Notepad 7.6.4 / SourceCookifier 0.7.3 via Plugins Admin / Folder structure:
                    C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\Config\SourceCookifier.languages.model.xml
                    C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\doc\SourceCookifier.README.TXT
                    C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\SourceCookifier\icons
                    C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\SourceCookifier\AddPolicy.bat
                    C:\Program Files (x86)\Notepad++\plugins\SourceCookifier\SourceCookifier\RemovePolicy.bat
                    The icons from the sub folder “icons” are not display in the Notepad++ itself.
                    (Anyhow possible to add a screenshot?)
