    Need help with Replacing lines
    2 Posts 2 Posters 461 Views
    • WTFerwarwaW
      WTFerwarwa
      I have about 100k lines like these
      LoydNova47:TEHHA3HFW35GG:cc9sttdcb6tkb8z31hs7i3p3sss8rx:hongjgd45td5wnumnpe4gzwn3iiiglsq09d0vptyll9mrc7p9d
      PierreIncendi5fary7:UNM7EAG4QBPHGY:vr2534igqrj1llisopis4l1yc1z4py:6p22mq1ruxfr8i3nz0cihl2bby6j944r4hcz602w9x99neftrd
      KlinklangHJunior7:EFTEXFGP5DWKBD:n6hbd3869c0h48kzg8r89rejg344qb:r8hq5i2yoladarotzkhlhe82kucirqmn26t9mne7jwjbuwiy3w
      And i want to change each line to only this
      can someone help me how to do that?
        Hello @ilya-levadny and All,
        Actually, you want to delete all characters located after the second colon character, included, of any line
        Indeed, not difficult with regular expressions !
        • SEARCH (?-s)^(.+?:.+?):.+
        • REPLACE \1
        • Check, preferably, the Wrap around option
        • Click, once on the Replace All button or several times on the Replace button
        An other formulation would be :
        • SEACRH (?-s)^.+?:.+?\K:.+
        • REPLACE Leave EMPTY
        This time, due to the \K syntax you must use the Replace All button, exclusively
        Notes :
        • The (?-s) in-line modifier means that dot ( . ) matches any single standard character, only
        • The .+?: part looks for the shortest non-null range of characters till a colon ( : )
        • The part between parentheses ( .+?:.+? ) is stored as group 1, which must be rewritten, during the replacement phase
        • At the end, the .+ syntax represents the rest of the line, after the second colon char, included, of the current line
        • In the second version, after matching the implicit group 1, the \K syntax resets the regex engine, so the final overall match is the part :.+ which corresponds to the second colon char with all the subsequent chars of current line, which are deleted as the replacement zone is empty
