    How to right mouse click File Open from current directory
    8 Posts 4 Posters 2.8k Views
    • Andy KlajA
      Andy Klaj
      Hi,
      When I try to use the Right Mouse click File Open menu item i have to specify the directory.
      For example if i have two files (File1.txt and File2.txt) in a directory and File1.txt has the following content then i can right mouse click the ‘/File2.txt’ and open it in a new tab
      File1.txt:
      ./File2.txt
      The problem is that witht he project that I am on does not include the director so the File1.txt content looks more like
      File1.txt
      File2.txt
      When I try to right mouse click File Open the above it is not recognized as a possible file to open.
      Can someone help me to allow for content liek ‘File2.txt’ to be recognized as a file in the current directory in Notepad++ ?
      Bonus - I noticed that when i double click the ‘File2.txt’ only the ‘File2’ is highlighted. Does anyone know how to set Notepad ++ so that the entire filename ‘File2.txt’ is highlighted?
      Thankyou
      Andrew
        Hello, @ady-klaj, and All,
        Assuming for instance, that you have a file, named Blablah.txt, in folder C:
        And let’s suppose that you have this line in a file :
        xxxxx C:\Blablah.txt xxxxx
        I’ve added a second line of uppercase letters just to locate the present cursor position
              ABCDEFGHIHKLMNO
        Then :
        • If you right-click in the first line, on the context menu option Open File, with caret on positions C to K, it opens C:\Blablah.txt file in Notepad++
        • If you right-click, in the first line, on the context menu option Open File, with caret on positions A,B, L, M, N or O , you get the error message The file you’re trying to open doesn’t exist.
        Now, if the filename ends the line, as below :
              ABCDEFGHIHKLMNO
        Then, it’s a bit different :
        • If you right-click in the first line, on the context menu option Open File, with caret on positions C to O, it opens C:\Blablah.txt file in Notepad++
        • If you right-click, in the first line, on the context menu option Open File, with caret on positions A or B , you get the error message The file you’re trying to open doesn’t exist.
        Now, a radical way to select a valid full pathname without bothering about caret location, would be :
        • Go to Settings < Preferences > Delimiter > Word character list
        • Select the option Add your character as part of word
        • Type in the 3 characters .\: in the field
        • Close the Preferences dialog
        From now on, a right-click at any location of a valid pathname OR a double-click on any part of it, followed with the choice of the Open file option, should open this file in Notepad++
          Alan Kilborn @Andy Klaj
          What is your definition of “the current directory in Notepad++”?
            Alan Kilborn @guy038
            @guy038 's posting hints that Open File is a not-real-smart feature. Many files these days have spaces in them, their names I mean of course. How is THAT going to work with this feature? Likely not too well.
              Indeed. A little birdie once told me that there’s someone working on a PythonScript improvement of the open-file-under-cursor, which I beta tested. When I’m home, I’ll have to look through my test cases to see if the local-directory-file was covered; if it is, I may put in a request for accelerated release (and point that someone to this thread); if it’s not in there, I may add a feature request. (No, I do not have permission to publish it for that someone.)
                Hello, @ady-klaj, @alan-kilborn, @peterjones and All,
                Really, I’m unforgivable ! I should have tested a file name or a folder name containing spaces, too ;-)) For instance :
                xxxxx C:\Bla blah.txt xxxxx
                In that case, it’s even worse ! Whatever the location of the caret, in the full pathname, it does not work :-((
                Finally, the correct way, in all cases, is to select all the pathname C:\bla blah.txt and right-click on the Open File option
                Actually, the context menu option should been named : Open Selected Pathname or File ;-))
                Now, it would be hard to find a correct algorithm to get a pathname or file selected, only from current position of caret !
                Indeed, let’s suppose the line, below, in a file, with rubbish xxxxx text and caret located between letters e and s of the test word
                xxxxx Small test.txt xxxxx
                And let’s suppose that a file name, with its extension, should contain word characters, dots or spaces ( very basic rule ! )
                Well, even if you scan text rightwards and leftwards, how to decide if the file name is :
                • Small test.txt
                • xxxxx Small test.txt xxxxx
                as you’ve included spaces as valid characters in filenames ?
                So, all in all, the fact of selecting pathname/filename, before a right-click on the context menu option Open File, seems rather pertinent !
                • PeterJonesP PeterJones unlocked this topic on
                  Bah, easy to forget filenames can have spaces, if you never use spaces yourself in your names.
                  I think I’ve scripted a reasonable way.
                  Here’s a script called OpenFilenameAtCaret.py:
                  # -*- coding: utf-8 -*-
                  #  OpenFilenameAtCaret.py (OFAC)
                  # references:
                  #  https://community.notepad-plus-plus.org/topic/17169/how-to-right-mouse-click-file-open-from-current-directory
                  #  https://github.com/notepad-plus-plus/notepad-plus-plus/issues/14579 "[Feature Request] Opening a file within Notepad++ and jump to line"
                  #  possibly relevant:
                  #   https://community.notepad-plus-plus.org/topic/16597/how-to-open-a-path-in-windows-explorer
                  #   https://community.notepad-plus-plus.org/topic/17836/i-can-not-understand-what-file-opens-this-option
                  #  maybe see https://www.oreilly.com/library/view/regular-expressions-cookbook/9781449327453/ch08s18.html
                  #  for newbie info on PythonScripts, see https://community.notepad-plus-plus.org/topic/23039/faq-desk-how-to-install-and-run-a-script-in-pythonscript
                  from Npp import *
                  import os
                  from ctypes import (WinDLL)
                  def position_range_generator(pos1=None, pos2=None):
                      if pos1 is None: pos1 = 0
                      if pos2 is None: pos2 = editor.getLength()
                      working_pos = pos1
                      if pos1 == pos2:
                          return
                      elif pos1 < pos2:
                          while working_pos < pos2:
                              yield working_pos
                              working_pos = editor.positionAfter(working_pos)
                      else:
                          while working_pos > pos2:
                              yield working_pos
                              working_pos = editor.positionBefore(working_pos)
                  def string_intersection(s1, s2):
                      set1 = set(s1)
                      set2 = set(s2)
                      intersection = set1 & set2
                      return ''.join(sorted(intersection))
                  def shift_held():
                      VK_SHIFT = 0x10
                      user32 = WinDLL('user32')
                      return (user32.GetAsyncKeyState(VK_SHIFT) & 0x8000) != 0
                  def ctrl_held():
                      VK_CONTROL = 0x11
                      return (user32.GetAsyncKeyState(VK_CONTROL) & 0x8000) != 0
                  def shell_open(arg, parameters=None):
                      # https://docs.microsoft.com/en-us/windows/win32/api/shellapi/nf-shellapi-shellexecutew
                      SW_SHOW = 5
                      return ctypes.windll.Shell32.ShellExecuteW(None, 'open', arg, parameters, None, SW_SHOW) > 32
                  class OFAC(object):
                      def __init__(self):
                          rect_sel_mode = editor.getSelectionMode() in [ SELECTIONMODE.RECTANGLE, SELECTIONMODE.THIN ]
                          if rect_sel_mode or editor.getSelections() > 1: return  # conditions not correct for running
                          file_absolute_path = file_line_number = None
                          (file_absolute_path, file_text_start_pos, file_text_end_pos) = self.abspath_to_file_at_caret()
                          if file_absolute_path is not None:
                              curr_line_end_pos = editor.getLineEndPosition(editor.lineFromPosition(editor.getCurrentPos()))
                              line_number_match_pos_tup = editor.findText(FINDOPTION.REGEXP, file_text_end_pos, curr_line_end_pos, r'"?:\K\d+')
                              if line_number_match_pos_tup is not None and line_number_match_pos_tup[0] - file_text_end_pos <= 2:
                                  file_line_number = int(editor.getTextRange(*line_number_match_pos_tup))
                              select_path_in_source_text = shift_held() and not ctrl_held()
                              open_containing_folder = shift_held() and ctrl_held()
                              if select_path_in_source_text:
                                  if file_text_start_pos != file_text_end_pos:
                                      editor.setSel(file_text_start_pos, file_text_end_pos)
                              elif open_containing_folder:
                                  folder_absolute_path = os.path.dirname(file_absolute_path)
                                  if os.path.isdir(folder_absolute_path): shell_open('explorer', folder_absolute_path)
                              else:
                                  if not isinstance(file_absolute_path, str):
                                      file_absolute_path = file_absolute_path.encode('utf-8')  # python2
                                  notepad.open(file_absolute_path)
                                  if file_line_number is not None: editor.gotoLine(file_line_number - 1)
                      def abspath_to_file_at_caret(self):
                          # initialize return values:
                          rv__existing_absolute_path = None
                          rv__pos_span_2tup = (0, 0)
                          curr_pos = editor.getCurrentPos()
                          curr_line_nbr = editor.lineFromPosition(curr_pos)
                          line_start_pos = editor.positionFromLine(curr_line_nbr)
                          line_end_pos = editor.getLineEndPosition(curr_line_nbr)
                          # get the current tab's directory for partial-path matching:
                          curr_dirname = os.path.dirname(notepad.getCurrentFilename())
                          illegal_filename_chars = '><"|?*\t'  # there may be more but these are the definites
                          illegal_filename_chars_single_char_regex = r'[><|?*\t]'  # note: double-quote is NOT included
                          # if text is selected, look at "exactly" what user has specified:
                          if editor.getSelections() == 1 and not editor.getSelectionEmpty():
                              test_name = editor.getSelText()
                              test_name = test_name.strip(' ' + '"' + illegal_filename_chars)  # give user some leeway with possible "bad stuff" on either end of selection
                              rv__existing_absolute_path = self.absolute_pathname_to_existing_file(test_name, curr_dirname)
                              if rv__existing_absolute_path is not None:
                                  rv__pos_span_2tup = ( editor.getSelectionStart(), editor.getSelectionEnd() )
                          else:
                              # find any illegal filename chars to the left and right of caret on current line; otherwise use start and end of current line positions
                              ft_tup = editor.findText(FINDOPTION.REGEXP, curr_pos, line_start_pos, illegal_filename_chars_single_char_regex)  # search backward toward start-of-line
                              line_left_pos = ft_tup[1] if ft_tup else line_start_pos
                              ft_tup = editor.findText(FINDOPTION.REGEXP, curr_pos, line_end_pos, illegal_filename_chars_single_char_regex)  # search forward toward end-of-line
                              line_right_pos = ft_tup[0] if ft_tup else line_end_pos
                              # quickest possible method (look to either side of the caret for first whitespace or double-quotes to delimit, or consider the entire line):
                              if rv__existing_absolute_path is None:
                                  for delimiting_regex in ( r'\s', '"' ):
                                      ft_tup_1 = editor.findText(FINDOPTION.REGEXP, curr_pos, line_left_pos, delimiting_regex)  # search backward toward start-of-line
                                      ft_tup_2 = editor.findText(FINDOPTION.REGEXP, curr_pos, line_right_pos, delimiting_regex)  # search forward toward end-of-line
                                          ft_tup_1[1] if ft_tup_1 is not None else line_left_pos,
                                          ft_tup_2[0] if ft_tup_2 is not None else line_right_pos
                                      if rv__pos_span_2tup[0] != rv__pos_span_2tup[1]:
                                          rv__existing_absolute_path = self.absolute_pathname_to_existing_file(editor.getTextRange(*rv__pos_span_2tup), curr_dirname)
                                          if rv__existing_absolute_path is not None: break
                              # go on a l..o..n..g..e..r search:
                                  for left_pos in position_range_generator(line_left_pos, curr_pos + 1):
                                      for right_pos in position_range_generator(line_right_pos, curr_pos):
                                          rv__pos_span_2tup = (left_pos, right_pos)
                                          test_name = editor.getTextRange(*rv__pos_span_2tup)
                                          if test_name[0] in ' ' + ':' + illegal_filename_chars:
                                              break  # can't start with these characters; go get next potential starting char
                                          if test_name[-1] in r' :\/': continue  # filenames don't reasonably end with space/colon/backslash/slash
                                          if len(string_intersection(test_name, illegal_filename_chars)) > 0: continue
                                          if rv__existing_absolute_path is not None: break  # get out of inner for loop
                                      if rv__existing_absolute_path is not None: break  # get out of outer for loop
                          if rv__existing_absolute_path is None: rv__pos_span_2tup = (0, 0)
                          return (rv__existing_absolute_path, rv__pos_span_2tup[0], rv__pos_span_2tup[1])
                      def absolute_pathname_to_existing_file(self, file_or_path_name_to_test, dir_for_partial_path=''):
                          retval = None  # return None if file not existing, otherwise return absolute path to it
                          if isinstance(file_or_path_name_to_test, bytes):
                              file_or_path_name_to_test = file_or_path_name_to_test.decode('utf-8')  # python2
                          file_or_path_name_to_test = os.path.expandvars(file_or_path_name_to_test)
                          if os.path.isfile(file_or_path_name_to_test):
                              retval = os.path.abspath(file_or_path_name_to_test)
                          else:
                              if len(dir_for_partial_path) > 0:
                                  retval = os.path.abspath(os.path.join(dir_for_partial_path, file_or_path_name_to_test))
                                  if not os.path.isfile(retval): retval = None
                          return retval
                  if __name__ == '__main__': OFAC()
                  How it works is that you put the caret somewhere in the text of the filename/path you want to open, then run the script (more on a better method to run the script, below).
                  The script will pick out the file from the context of the caret and open it into a new Notepad++ tab (or, if the file had previously been open in a tab, it will make that tab active).
                  The script will work on a full pathname in the text, or a partial path (e.g. ..\fubar.c) using the currently active filetab’s folder as the base folder.
                  It can work with forward slashes in a path, e.g. c:/folder1/folder2/foo.txt and even doubled backslashes, e.g. D:\\folder3\\bar.py.
                  Additionally, if the filename in the text is followed by a colon (:) and then an integer value, e.g. foo.txt:27, then the integer will be considered a line number, and the caret will be placed at the start of that line when the new filetab becomes active. This subfeature originates with a request HERE for that functionality.
                  It’s in the comments of the script, but for emphasis: for newbie info on PythonScripts, see https://community.notepad-plus-plus.org/topic/23039/faq-desk-how-to-install-and-run-a-script-in-pythonscript
                  Now for a better way to run the script (than, presumably, running it from the menu):
                  So the default editor right-click context menu has this entry:
                  And that’s fine, but that is the Notepad++ version of the command, which, as discussed in this thread, a bit lame.
                  If we convert this entry into one that runs the script instead, we get improved functionality. As a bonus, we can also achieve some additional functionality:
                  • holding Shift while running from the right-click context menu allows quickly selecting the filename text
                  • holding Shift and Ctrl while running from the right-click context menu will open an Explorer window in the folder in which the file at the caret lives
                  The new context menu entry could look like this:
                  Notice that there is some reminder text there about adding in the Shift and Ctrl keys, in the form of +S= and +S+C=.
                  Here’s what to do to contextMenu.xml to achieve the above (for further detail, see the FAQ entry cited above):
                  • comment out the existing Open File entry, i.e., make it look like this: <!-- <Item MenuEntryName="Edit" MenuItemName="Open File"/> -->
                  • add this line below it: <Item PluginEntryName="Python Script" PluginCommandItemName="OpenFilenameAtCaret" ItemNameAs="Open FILE under caret (+S=SELECT it; +S+C=Open its FOLDER)"/>
                    I suppose I should have mentioned above that the script will work with filenames/paths that include spaces, whether or not the filename is wrapped in double-quotes (the typical way to refer to Windows names with embedded spaces.
                    Some additional examples of what will work (the I character is included to show a reasonable right-click/caret point):
                    • I am some text with c:\folder with spaceIs\file with spaces.txt a filepath right in the middle of me
                    • And of course wrapping in double quotes works "c:\foldeIr with spaces\file with spaces.txt" too
                    • Even without spaces you can have other text directly adjoining the name |c:\teIst1\test2.txt|
                    • Even other characters directly adjoining will work c:\test3\tIest4.txtzzzz (opens test4.txt – presuming test4.txtzzzz / test4.txtzzz / test4.txtzz / test4.txtz all don’t exist – if any did, they’d be opened before test4.txt )
