    How to remove "dots"?
    3 Posts 2 Posters 3.2k Views
    • BelzemosB
      Belzemos
      Hello!
      I use Notepad++ only as a better alternative to Windows Notepad, I’m not a programmer.
      Notepad++ worked fine for me in Windows 7, I now moved to Windows 10 and installed a new version of Notepad++. It’s still just as great for me but now it shows some lines with dots that weren’t shown before (please check the link for a screenshot - the dots in the first-empty line):
      [https://i.imgur.com/z99kX2n.png](link url)
      How can I remove those? I don’t want them and I can’t find a setting to do it.
      Thank you!
        I assume you mean the vertical dotted grey lines. Those are the indent indicators. You can toggle that setting using View > Show Symbol > Show Indent Guide
        • BelzemosB
          Belzemos
          That’s it. Thank you!
