    Notepad++ Problem with sorting lines
    4 Posts 3 Posters 1.1k Views
    • John DestinyJ
      John Destiny
      Hi,
      I have this line:
      Line1-10 - Art
      Line11-20 - Biology
      Line21-30 - Film
      Line31-40 - Geography
      Line41-50 - History
      Line51-60 - IT
      Line61-70 - Science
      Line71-80 - Sport
      This is what I need:
      Line1 - Art
      Line2 - Biology
      Line3 - Film
      Line4 - Geography
      Line5 - History
      Line6 - IT
      Line7 - Science
      Line8 - Sport
      Line9 - Art
      Line10 - Biology
      etc.
      Alan KilbornA Meta ChuhM 2 Replies Last reply Reply Quote 0
        Alan Kilborn @John Destiny
        @John-Destiny
        I would do:
        Find: ^Line\d+-\d+
        Replace: Line
        Search mode: Reg Expression
        Then, follow that up with inserting a column of ascending digits (see the Column Editor on the View menu).
        • Meta ChuhM
          Meta Chuh moderator @John Destiny
          @John-Destiny
          yes, @Alan-Kilborn 's suggestion seems to be the best and easiest way to do so.
          if you need help on the column editor:
          once you’ve run alan’s regex with “replace all”, hold the [alt] key and mark (draw) a cursor-line from the end of the first word Line to the end of the last word Line like shown at the screenshot below.
          Imgur
          then open column editor, select number to insert, with initial number 1 and increase by 1, and hit ok.
          Imgur
          after that, you list will look like this.
          Imgur
            If you have a lot of lines, you may end up with space(s) between Line and the (first) number. Use the following to remove those:
            Find ^Line\h+(?=\d)
            Replace Line
            Again, search mode is Reg Exp
