    no output when using kivy in python in notepad++
    16 Posts 2 Posters 2.7k Views
    • Sean LaceyS
      Sean Lacey
      python works fine, i get text output in the command line, and in idle i get the windowed output i expect, but not when i use notepad++ which i really enjoy.
      Eko palypseE 1 Reply Last reply Reply Quote 1
      • Eko palypseE
        Eko palypse @Sean Lacey
        @Sean-Lacey
        How do you start your kivy/python program?
        • Sean LaceyS
          Sean Lacey
          I know I installed python correctly, i put it in the path and everything, its been a while since i installed notepad. to install kivy i went into the windows command prompt and typed “python -m pip install kivy”. i know this worked because i can fully use kivy using the idle interface. just not in the Notepad++ interface.
          • Eko palypseE
            @Sean-Lacey
            sorry but you did not answer my question how you start your program.
            Using run menu and if how? Using NppExec, if so what did you specify to run the program?
            • Sean LaceyS
              Sean Lacey
              sorry, yes it was nppexec
              Eko palypseE 1 Reply Last reply Reply Quote 0
              • Eko palypseE
                @Sean-Lacey
                • Sean LaceyS
                  Sean Lacey
                  im not sure what you mean what did i specify (sorry, pressed submit before i was done and had to wait a minute)
                  • Eko palypseE
                    Eko palypse
                    you need to specify which python interpreter you want to use, with which parameters to execute the program
                    • Sean LaceyS
                      Sean Lacey
                      im using python 3.7.1. its been a while since i set notepad up, where would i find the parameters
                      • Eko palypseE
                        @Sean-Lacey
                        you will see it if you press F6 - as long as you have not reassigned the standard NppExec shortcut
                        • Sean LaceyS
                          Sean Lacey
                          i have not reassigned anything except F7 is now set to run python
                          this is what im getting "C:\Users\(MYNAME)\AppData\Local\Programs\Python\Python37-32\python.exe “$(FILE_NAME)”
                          • Eko palypseE
                            @Sean-Lacey
                            this doesn’t work for gui frameworks like kivy.
                            Use something like
                            cmd /C cd $(CURRENT_DIRECTORY) && "C:\Users\(MYNAME)\AppData\Local\Programs\Python\Python37-32\python.exe" -t -B -u "$(FILE_NAME)"
                            • Sean LaceyS
                              Sean Lacey
                              just confirming, am i supposed to copy what you sent me and replace what i sent you for it
                              • Eko palypseE
                                @Sean-Lacey
                                normally yes, as long as you sent me the whole configured call setup.
                                • Sean LaceyS
                                  Sean Lacey
                                  i did, i check it now
                                  • Sean LaceyS
                                    Sean Lacey
                                    it worked thank you so much
