    Stuck in "Administrator" mode...how to get out?
    35 Posts 10 Posters 11.9k Views
      Thanks for everyone’s efforts so far…
      • Meta ChuhM
        Meta Chuh moderator
        you can’t imagine how hard it was for me to keep my finger off that upvote button right now 😂😂😂 ;-)
        • Ilkka LindblomI
          Ilkka Lindblom
          Re-enabling UAC fixed this issue for me. Unfortunately, probably due to all the uninstalls and reinstalls I made while trying to fix it, NPP seems to have lost my saved session. Still I’m glad to have it working again, so thanks a lot people.
          Meta ChuhM 1 Reply Last reply Reply Quote 3
          • Meta ChuhM
            Meta Chuh moderator @Ilkka Lindblom
            side note to @Alan-Kilborn, as this thread was resurfaced by @Ilkka-Lindblom :
            i guess my evil upvote finger’s incubation period for “Thanks for everyone’s efforts so far…” is over.
            my hooked, crooked finger just went haywire on that damned button … and i sincerely hope you won’t notice it at all 😉
              So an update to this thread…
              I’m still in Notepad++ 7.5.x land for my day-to-day Notepad++ usage, but recently I had reason to grab a portable 7.6.4…and I noted that running this one it DOES NOT end up in Administrator mode. By this I mean no [Administrator] in the title bar, and able to drag-n-drop files from a non-admin Explorer window.
              So just a little nicety waiting for me when I get around to making the Plugin Mgr -> Plugin Admin chasm jump! :)
              I don’t know what changed in N++ so that this now happens, but I’m going to mark this thread SOLVED if I can.
              • Meta ChuhM
                Meta Chuh moderator @Alan Kilborn
                hi @Alan-Kilborn
                aaahhhhh … the upvote thread, lol
                i love revisiting things like these 💚
                i’ve got a big smile on my face right now 😃
                ps:
                very intriguing … if 7.6.4 and above don’t trigger administrator mode, but 7.6.3 and below do, could it be that it gets triggered by the existence of a code signing cert on the older versions on your system ?
                i have never heard about a behaviour like this if something is code signed, but 7.6.4 was the first release without windows code signing. ⁉️
                  Alan Kilborn @Meta Chuh
                  @Meta-Chuh
                  I did not do exhaustive testing, but I just went back and tried 7.6.3 and 7.6.2 portable versions. Both of these showed [Administrator] in the title bar. Trying 7.6.4 again…still no [Administrator] there! :)
                  • anselme16A
                    anselme16
                    good lord the source code determining if the application should launch in administrator is ugly.
                    here is a clarified version of it :
                    Notepad_plus::Notepad_plus()
                    :   _isAdministrator (false)
                        // Determine if user is administrator.
                        winVer ver = NppParameters::getInstance()->getWinVersion();
                        if (ver >= WV_VISTA || ver == WV_UNKNOWN)
                            SID_IDENTIFIER_AUTHORITY NtAuthority = SECURITY_NT_AUTHORITY;
                            PSID AdministratorsGroup;
                            if(AllocateAndInitializeSid(&NtAuthority, 2, SECURITY_BUILTIN_DOMAIN_RID, DOMAIN_ALIAS_RID_ADMINS, 0, 0, 0, 0, 0, 0, &AdministratorsGroup))
                                BOOL isAdmin;
                                if(CheckTokenMembership(NULL, AdministratorsGroup, &isAdmin))
                                    _isAdministrator = isAdmin;
                                FreeSid(AdministratorsGroup);
                    Sorry i couldn’t resist.
                      I’m confused – why is it ugly? Looking at the existing code (below) I’m struggling to see any significant ugliness or even any real differences between it and your version:
                          BOOL is_admin;
                              is_admin = AllocateAndInitializeSid(&NtAuthority, 2, SECURITY_BUILTIN_DOMAIN_RID, DOMAIN_ALIAS_RID_ADMINS, 0, 0, 0, 0, 0, 0, &AdministratorsGroup);
                              if (is_admin)
                                  if (!CheckTokenMembership(NULL, AdministratorsGroup, &is_admin))
                                      is_admin = FALSE;
                          else
                              is_admin = false;
                          _isAdministrator = is_admin ? true : false;
                      • Alex BoyceA
                        Alex Boyce
                        I have also experienced this issue and I was able to resolve it.
                        First, I got into this situation with Notepad++ itself. I tried to edit a file in the Program Files tree and was prompted by Notepad++ that I needed to be in admin mode to do that and did I want to restart Notepad++ in admin mode. I clicked Yes and have been in admin mode ever since.
                        As noted above, drag and drop from a non-admin explorer doesn’t work, but the context menu Open with Notepad++ does, so it wasn’t too much of a hardship. However, it is annoying, so I tried to find out how to turn it off. There is no setting within Notepad++ for it, nor is the compatibility mode tab on the properties sheet checked.
                        I did a google search and found this thread. One of the suggestions was to search the registry for Notepad++. I tried this and found the magic key. Under HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatability Assistant\Store there was a value named C:\Program Files\Notepad++\notepad++.exe. I deleted this value and restarted Notepad++ and it is in normal mode again.
                        I have been able to repeat this by dragging a file from the Program Files tree into Notepad++ which works fine, but when you try to save it, the reopen in admin mode prompt appears.
                        Thanks for the help.
                        EkopalypseE 1 Reply Last reply Reply Quote 4
                          Ekopalypse @Alex Boyce
                          @Alex-Boyce
                          thx for the information.
                          Because you ended with Thanks for the help. I’m unsure if you expect an answer
                          on an implicit question, which I was not able to identify (non-native speaker).
                            Similar discussion relating to the original topic here is continued IN-THIS-THREAD …
