    Problem with Ziped Version and Plugins
    3 Posts 2 Posters 708 Views
    • dtoxic64D
      dtoxic64
      Hi all, i downloaded N++ 7.6.2 the zipped version, if i unzipit it in Program Files i cant use/see the new plugin admin (manager)
      but if i unzipit in say C:\ everything works, can some one help me with this? i would like to have N++ in Program Files
      • Meta ChuhM
        Meta Chuh moderator @dtoxic64
        @sick13
        welcome to the notepad++ community
        if you want to put notepad++ into %programfiles% or %programfiles(x86)%, you will have to use the installer version, as this uses it’s program directory as a read only source and stores the plugins in a separate folder at %programdata%\Notepad++\plugins, according to windows guidelines.
        plugins admin of the portable version will be deactivated by design if notepad++ detects that it is launched as a portable version of notepad++ from %programfiles% or %programfiles(x86)% because of permission issues to those folders.
        if you still want to use the portable version, you will have to put your portable version of notepad++ somewhere else.
        eg. a new folder called C:\Applications\Notepad++
        • dtoxic64D
          dtoxic64
          ok thx for the info, i appreciate it
