    regexp with hashes help
    regexregex
    16 Posts 3 Posters 3.1k Views
    • Scott SumnerS
      Scott Sumner @patrickdrd
      @patrickdrd
      I’m certainly willing to assist, but I have no clue what “send me the first request to check and I’ll tell you what results I want omitted” means. (Which to me is the long form of my earlier response of “???”.)
      • patrickdrdP
        patrickdrd
        thanks a lot,
        I was talking about the original, first message,
        ignore the follow-up for now,
        we’ll talk about them after the initial results
          Hello, @patrickdrd, @scott-sumner and All
          Scott, I suppose that @patrickdrd was expecting your first regex attempt, in order to test it on real data ! However, I must admit that the @patrickdrd’s formulation looks like more as an imperative order than a polite request for some regex help :-(
          Anyway, @patrickdrd, I’ll try to give you some hints !
          Here is, below, the general form of the regex S/R which deletes all lines containing, exactly, n times the Char character ;-))
          SEARCH ^(?:([^Char\r\n]*)Char){n}(?1)\R
          REPLACE Leave EMPTY
          In your case, as you, probably, want to delete all lines containing, exactly, 1 hash char, only, whatever its location, the correct regex becomes :
          ^(?:([^#\r\n]*)#){1}(?1)\R
          which can be shortened as :
          ^([^#\r\n]*)#(?1)\R
          Notes :
          • The [^#\r\n]* part represents the longest range, even null, of characters different from # and line-breaks, stored as group 1 and re-used, after the # symbol, in the (?1) sub-routine call syntax, which is equivalent to [^#\r\n]*
          • As usual, the \R form matches any line-break, whatever the file type ( Windows, Unix or Mac )
          Scott SumnerS 1 Reply Last reply Reply Quote 2
          • patrickdrdP
            patrickdrd
            sorry guys, I didn’t mean to be impolite, I just didn’t express myself properly
            • patrickdrdP
              patrickdrd
              ok, I’ve just tested guy038’s suggestion and it’s not “safe” because
              it matches these lines I would like excluded:
              @@.jpg#$image,domain=comando-filmes.org
              @@.png#$image,domain=fbfriendrequest.com|igflash.com|likesgroup.com
              *.png#$image,redirect=2x2-transparent.png,domain=idsly.com
              *.png#$image,redirect=2x2-transparent.png,domain=premiumtoss.com
              *.jpg#$image,redirect=2x2-transparent.png,domain=300mbfilms.org
              *.png#$image,redirect=2x2-transparent.png,domain=golrojadirecta.com
              *.gif#$image,redirect=1x1-transparent.gif,domain=totaldebrid.org
              .png#$image,domain=driverdestek.com
              so maybe my best shot is #\s
              • Scott SumnerS
                Scott Sumner @guy038
                Gotta love the sub-routine syntax…why write something like [abc]{5} when you can write (?+1)(?'name'[abc])(?1)(?-1)(?&name) ? :-D
                Example shamelessly stolen from here after I read up on it…and OK, that example includes named groups as well…but all good stuff (that works in N++).
                • Scott SumnerS
                  @patrickdrd
                  Hey, you’ve been around long enough to know to indent every line of example text with 4 spaces before posting. :-)
                  (Noticed that you escaped some * but apparently not all because some of your text is in italics…way easier to just indent 4 and forgetaboutit)
                    Hi, @patrickdrd, @scott-sumner and All
                    Scott, your regex use of the (?1) syntax made me laugh a lot ;-)) Of course, it would be ridiculous to use such a regex !
                    So, the generic regex S/R, of my previous post, which deletes all lines containing, exactly, n times the Char character can, also, be written :
                    SEARCH ^(?:[^Char\r\n]*Char){n}[^Char\r\n]*\R?
                    REPLACE Leave EMPTY
                    Now, generally speaking, when you want to delete some lines of a file, based on a criteria, just determine :
                    • The common characteristics of all the lines which have to be to kept
                    OR the opposite :
                    • The common characteristics of all the lines which have to be deleted
                    patrickdrd, reading more carefully, and from your last example, it’s seemed that you would like to delete, either :
                    • All lines, containing the #$ string
                    • All lines, containing more than one hash character #
                    In that case, use the regex S/R, below :
                    SEARCH ^.*#(.*#|\$).*\R?
                    REPLACE Leave EMPTY
                    • patrickdrdP
                      patrickdrd
                      no, sexually l actually I want to keep those lines and the ones posted above, it’s an awkward one, I know
                      • patrickdrdP
                        patrickdrd
                        damn auto correct…
