    Pls help
    help
    4 Posts 2 Posters 1.3k Views
    • Sarfaraz Safwan SaeedS
      Since few days i"m facing a problem . When i want to open notepad++ it shows “Dll signature verification failed” also “Library verification failed”. i’m using current version notepad++. I have tried my best to solve it by uninstall then reinstall .
      • chcgC
        chcg
        Version 7.5.9? Which kind of installation (msi or zip)? 32bit or 64bit. There is a crypto check between notepad++.exe and the corresponding SciLexer.dll to avoid security issues via hijacked dlls.
          yes 7.5.9 not zip 64 bit . can you suggest variant of it ?
          • chcgC
            chcg
            On which windows version? See also https://notepad-plus-plus.org/community/topic/15739/faq-desk-request-for-help-without-sufficient-information-to-help-you.
            You could try a variant from https://notepad-plus-plus.org/download/v7.5.9.html. Maybe starting with
            Notepad++ minimalist package 64-bit x64
