    two questions on my first plugin
    4 Posts 2 Posters 1.7k Views
    • Mario RosenbohmM
      Mario Rosenbohm
      Hello,
      i now programing on my first npp plugin (in C#) and i have any little questions ;-)
      a) Is there exist an event or an message when the user change to another document?
      b) Is exist an example or dev-guide for using localization?
      Thats all for the begin.
      regards Mario
      • dinkumoilD
        dinkumoil
        I’m only able to tell you something about your question a)
        There is a notification called NPPM_BUFFERACTIVATED (see here (slightly outdated) and here (up to date)). It is send to a plugin whenever a document’s text buffer (i.e. its tab) gets activated.
        I’m a plugin author too (see here) thus I know that there are some pitfalls with NPPM_BUFFERACTIVATED. Activating a buffer often happens even in situations where you do not expect it.
        Especially if your plugin does something with a text buffer which has to be done only one times you need to implement some sort of buffer management to remember that a certain buffer already has undergone your manipulations.
        I personally ended up with a dictionary: The keys are buffer IDs and the values are the full paths of the related files. I solved it this way because it can happen that an already closed buffer ID gets reused by another file.
        • Mario RosenbohmM
          Mario Rosenbohm
          Hello dinkumoil,
          thanks for suggestion, it is exactly what i search.
          For all other C#-developers:
          1. In file Main.cs write a new function with header “internal static void bufferIsActivated()”
            this function is called by eventmanager on 2.
          2. In file PluginInfrastructure/UnmanagedExports.cs in the function “static void beNotified(IntPtr notifyCode)” add follow code above the else statement:
                 else if (notification.Header.Code == (uint)NppMsg.NPPN_BUFFERACTIVATED)
                     Main.bufferIsActivated();
          And now is calling your “bufferIsActivated”-function by change / activate a other tab.
          thanks and regards
          Mario
          • Mario RosenbohmM
            Mario Rosenbohm
            Hello everyone,
            “see the forest for the trees” 8-)
            in file PluginInfrastructure/UnmanagedExports.cs in the function “static void beNotified(IntPtr notifyCode)” in the else statement
                    else
                        Main.OnNotification(notification);
            … Main.OnNotification(notification); … oh no
            That is an callback. I am so stup…
            have a nice day
            Mario
