    [Bug] Auto indent doesn't work when recording macro
    4 Posts 3 Posters 986 Views
    • SanderBouwhuisS
      SanderBouwhuis
      I have a very weird bug.
      I have auto indent on when working on C++ source code and that works great. However, when I do a macro, the auto indent fails. This is really problematic as that makes doing macro’s useless (for C++ source code).
      Could this please be fixed?
        You might want to read this thread, which also dealt with macros interfering with auto-indent.
        • SanderBouwhuisS
          SanderBouwhuis
          Ok, it seems I’m not the only one who encountered this bug.
          So, is this on the bug list to fix? I saw some suggestions that are only useful if you want to keep a macro. I often do quick macros, so I can’t really add all those extra lines manually. That would defeat the whole purpose of doing a quick macro.
          Should I report this bug somewhere else?
          • Scott SumnerS
            Scott Sumner @SanderBouwhuis
            @SanderBouwhuis
            See here. IMPORTANT: Search to see if it already exists before creating something new.
