    Need help search and replace with wildcards
    3 Posts 2 Posters 1.3k Views
    • Patrick Huebgen6P
      Patrick Huebgen6
      Need to replace , with . in a json file but only for certain lines
      I have many lines that look like this
      , “VALSUM”:“92,55964588409961”
      	, "VALSUM":",25"
      	, "VALSUM":"9266,34657"
      and only should replace lines that contain VALSUM all other lines with comma should stay untouched
      I was hoping to solve it with regex
      “VALSUM”:“\d*,\d*” seems to work so I find the line but replace
      “VALSUM”:“\d*.\d*” does not work
      Please help
      Paul
        Terry R
        @Patrick-Huebgen6
        Good attempt. As you say your find regex worked. Unfortunately you cannot use the same type of information in the replace string.
        May I suggest you read
        https://notepad-plus-plus.org/community/topic/15765/faq-desk-where-to-find-regex-documentation
        for good documentation on how a regex works. I have tried looking for good information on the replace field, but most concentrate on the Find field so you might need to look quite hard. If I find one i will post back.
        In the meantime use the following:
        Find What:(VALSUM":"\d*),(\d*)
        Replace with:\1\.\2
        You will see I put brackets around 2 groups in the find window. These are referenced by \1 and \2 in the replace window. As the “.” is special I had to put a ‘delimiter’ before it so that it’s recognised as being the “.” character. I tested it
        See if that helps you.
        • Patrick Huebgen6P
          Patrick Huebgen6
          Thank you - worked perfect!
