    Notepad ++ doesn't remember position in document after changing tab
    4 Posts 3 Posters 999 Views
    • Alberto BalsalmA
      Alberto Balsalm
      Hi,
      I have this really annoying problem which makes me lose a lot of time.
      I read that people had this problem years ago and that turning XML Tools off would resolve it.
      I don’t have that plugin in my plugin list.
      Where does the problem come from?
      Thanks a lot
      • Nat TardisN
        Nat Tardis
        Same exact issue, just appeared recently.
        Renaming the plugins folder didn’t do anything. I don’t have the XML Tools plugin.
        Running as admin doesn’t fix.
        • Scott SumnerS
          Scott Sumner
          It seems to be a known issue with a fix coming soon: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/4571
          • Nat TardisN
            Nat Tardis
            Thank you for notifying us !
