    Unofficial strings for translations
    Scheduled Pinned Locked Moved Translation
    32 Posts 7 Posters 99.0k Views
      Hi Batagy, Yaron, Roberto and All,
      2 New items, in version v6.8.8 :
      In the <Scintillas> node :
      <Item id="6235" name="No edge"/>
      In the <Commands> node :
      <Item id="47012" name="Debug Info"/>
      Roberto, I agree to what you said in your last post : we should get little feedback from Don, and/or from the contributors, about these translation matters !
      It doesn’t seem so difficult to add these additional items to the English.xml file, only, under the localization folder, even if they are absent, in the others .xml language files :-)
      • YaronY
        Yaron
        Thank you guy038.
        Happy New Year.
        • batagyB
          batagy
          Please find update here.
          Below 1 items were added to the master English.xml, as part of PR #759, so these are not anymore unofficial:
          Under <ColumnEditor title=“Column Editor”>
          <Item id=“2036” name=“Repeat :”/>
          Below 6 items are choosed not to be included in translations by Don.
          Still you can include them in your translations for your responsibility:
          Under <Delimiter title=“Delimiter”>
          <Item id=“6257” name=“bla bla bla bla bla”/>
          <Item id=“6258” name=“bla bla bla bla bla bla bla bla bla bla bla”/>
          Denied by Don in PR #542.
          I guess this is not included in master file because it can be understood in other languages. :)
          These 3 items are only appearing in menu if “Customize Toolbar” plugin is installed.
          For Customize Toolbar 4.0 (this version is installed by default from Plugin manager!):
          Under <Commands>
          <Item id=“44012” name=“Hide Line Number Margin”/>
          <Item id=“44013” name=“Hide Bookmark Margin”/>
          <Item id=“44014” name=“Hide Folder Margin”/>
          For Customize Toolbar 4.1 the ID’s are changed! (4.1 can be installed manually):
          Under <Commands>
          <Item id=“44212” name=“Hide Line Number Margin”/>
          <Item id=“44213” name=“Hide Bookmark Margin”/>
          <Item id=“44214” name=“Hide Folder Margin”/>
          These lines are not supported by Don in the master English.xml. Quote from him:
          “Plugin translations will never be in localization file - not only because of maintenance problem, but especially the id of plugin commands are assigned dynamically.”
          Under <Cloud title=“Cloud”>
          <Item id=“6261” name=“Please restart Notepad++ to take effect.”/>
          Denied by Don in PR #759.
          Quote from him:
          “Item id=“6261” is used also for “Invalid path”, it’s currently hard coding so I prefer to keep it untranslatable.”
          Otherwise, this item just needs to be uncommented.
          The complete known real unofficial items are these 3 below, for version 6.8.8, modified on 2016.02.14:
          Under <DefaultDir title=“Default Directory”>
          <Item id=“6430” name=“Use new style save dialog (without file extension feature)”/>
          Under <Scintillas title=“Editing”>
          <Item id=“6235” name=“No edge”/>
          Under <Commands>
          <Item id=“47012” name=“Debug Info”/>
          PR #1475 is created for this latter three!
          • rddimR
            rddim
            From Notepad++ 6.9
            Under <Commands>
            <Item id="44085" name="Folder as Workspace"/>
            but can’t find how to translate the title bar of the panel when this option is activated, also the right click menu in it. Also in Preferences -> MISC. -> Workspace file ext.: is untranslatable
            • rddimR
              rddim
              Under <MISC title=“MISC.”>
              for Preferences -> MISC. -> Workspace file ext.:
              <Item id="6337" name="Workspace file ext.:"/>
              • rddimR
                rddim
                For the next version
                Under <Commands>
                <Item id="41022" name="Open Folder as Workspace"/>
                batagyB 1 Reply Last reply Reply Quote 0
                • batagyB
                  batagy @rddim
                  @rddim
                  Hi rddim!
                  Thanks a lot for posting the new items.
                  Actually i’m still waiting the previous PR #1475 to be implemented first. It will be 2 months soon since it registered, bit it’s still not even assigned to anybody.
                  It’s a little bit indeed annoying and demotivating that how us translators are so much ignored.
                  • rddimR
                    rddim
                    //offtopic
                    hi @batagy
                    I’m completely agreed with you. It is hard to keep translations up-to-date. In Mozilla Firefox I use an addon that track the changes of the menuCmdID.h source code file. You can try someone, there are tons of addons :)
                    • rddimR
                      rddim
                      Under <Commands>
                      <Item id="44097" name="Log Monitoring"/>
                      • JNylsonJ
                        JNylson
                        In version 7.5.5
                        <Folder title=“Folder && Default”>
                        • <Item id=“21127” name=“Styler”/>
                        • scootergrisenS
                          scootergrisen
                          When checking for updates the dialog title is:
                          “Notepad++ update” and dialog message is:
                          “No update is available.”
                          I would like those to be translateable.
                          • batagyB
                            batagy @JNylson
                            @JNylson
                            Hi!
                            I’m no sure if you’re right.
                            We have already 4 ‘Styler’ strings in that block, but neither id is 21127. We have these 4 below:
                            <Item id=“21102” name=“Styler”/>
                            <Item id=“21227” name=“Styler”/>
                            <Item id=“21327” name=“Styler”/>
                            <Item id=“21427” name=“Styler”/>
                            I don’t see any untranslated item in master english.xml which needs additionally.
