    another search and insert(=delete) problem
    3 Posts 2 Posters 897 Views
    • Krokodils FreundinK
      Krokodils Freundin
      actually i am completely stumped - maybe someone can help me…
      Using search and insert i want to replace (therefore delete) any entries in a text looking like that:
      [1 Kekse]
      [22 Kekse]
      Can somebody please help? Thanks.
        It would be nice if you showed what you tried, or at least what your thought process was: “If I were doing this manually, here are the explicit pieces I would look for to determine whether something was a match or not”. For example, I see that and I say "I want to delete lines that start with a bracket, then has one or more digits, a space, the exact text “Kekse”, end bracket, and end of line.
        I then convert that to regex syntax.
        Given the data:
        header
        [1 Kekse]
        [1 something else]
        random text
        [22 Kekse]
        footer
        with FIND = “\[\d+ Kekse\](\R|\Z)” and REPLACE = “” (empty), I get
        header
        [1 something else]
        random text
        footer
        which would, I believe, match your limited description.
        (I have tried to be more helpful and less preachy this time. However, if you are going to have more regex questions, I highly recommend trying to learn a little of the regex syntax yourself. It’s useful for more than programmers, as you can see. At some point, I have a feeling that asking for freebies will stop working for you: first in this forum, then in the next forum you try, and so on.)
        For other users who might be reading this: if you want to learn more, follow the links in this FAQ about regex documentation
          Krokodils Freundin
          thank you very much.
