    Notepad++ 7.5.8 - x64bit compatible with ThinApp sequencing or not?
    1 Posts 1 Posters 738 Views
    • Monika RajputM
      Monika Rajput
      Hi All,
      I’m currently working on Notepad++ 7.5.8 latest version for 64bit target platform(Win 7x64). Hence I’m using x64 bit installer i.e. “npp.7.5.8.Installer.x64.exe”.
      I have to sequence this application via Thinapp 5.2.2 sequencer. After sequencing I did not observe any context menu for this application. (Note: Source gives context menu option) While if I normally create MSI application by capturing via Pace suite tool, Context menu appears, but the same when I sequence MSI with thinapp, I did not get context menu. (Which means no context menu appears via installer sequencing or MSI sequencing).
      As I tried lot many options to make it work. Wanted to know if Notepad++ 64 bit is compatible with thinapp sequencing or not?
      Or is there any other solution which gives me context menu same as per the source.
      Please suggest.
