    Problem with syntax highlighting
    3 Posts 2 Posters 1.5k Views 2 Watching
    • N Offline
      niente0
      Hi, in the latest version of Notepad++ (v7.5.4) there’s a bug related to syntax highlighting.
      If I double-click on an asp file Notepad++ opens it but syntax is not highlighted as usual.
      But if I close the window and double-click again on the same file, this time it opens correctly and syntax is highlighted.
      Can you please check and fix this problem?
      Thank you
      • PeterJonesP Online
        v7.5.4 is not the latest version. Version 7.5.8 was released July 23. If you go to https://notepad-plus-plus.org/download/ , you can always see what the most recent version is.
        This FAQ will explain where to make a bug report so that the developers will actually take note.
        • N Offline
          niente0
          Hello, I updated Notepad++ to the latest version and it seems to work ok!!
          Thank you :-)
