    Regualr Expression Help
    moving datarex
    3 Posts 2 Posters 3.9k Views
    • Mike KovachM
      Mike Kovach
      Have a small task to merge data into individual lines.
      What I am looking to do is like the following:
      libogg-Red Hat Inc.
      1.1.3
      THERE IS A SPACE HERE and then other like data after the sapce.
      Thake those two lines and have it look like libogg-Red Hat Inc.,1.13
      and then remove the empty space. I’m looking to do this for 20000 rows of data. ANy one have any ideas on how to accomplish this?
      • jonandrJ
        jonandr
        Replace
        (.+)\r\n(.+)
        with
        \1, \2
        Then remove the empty lines.
        Mike KovachM 1 Reply Last reply Reply Quote 0
        • Mike KovachM
          Mike Kovach @jonandr
          Worked perfectly, that you.
